-   -   Help identify this wheel (https://67-72chevytrucks.com/vboard/showthread.php?t=597865)
Bigdock 09-23-2013 09:39 PM
It's a stock chevy wheel with 5 on 5 bolt pattern with center hole big enough to go over my drum on my 79 c10 but I only have one and want to run them on my 64 if I can find 3 more any help is thankfulAttachment 1155076
[size=1][i]Posted via Mobile Device
Bigdock 09-23-2013 09:44 PM
Re: Help identify this wheel
This is another shot of it all the wheels I'm finding where the inner wheel joins the outer ring it's flush in the pic you can clearly see this wheel has maybe 1/2-3/4 inch lip any help is thankful. Attachment 1155078
TJ's Chevy 09-23-2013 10:00 PM
Probably came off a 70's chevy or gmc.
Bigdock 09-23-2013 10:19 PM
That's what I thought too but everything I'm finding is not the same where the inner joins the outer it's flush and in the second pic you can clearly see mine isn't flush
07XCSBZ71 09-23-2013 10:51 PM
I got a few sets off a late 70's-early 80's G10 Vans. Try Bobby's junkyard off pea ridge. I don't think Babe's would have a set,but you can check. If you can't find any, I might be able to put a set together for you. I can bring them off the mtn next time I come down to Clermont.
Bigdock 09-24-2013 12:33 PM
I'll look around I guess that's why I wasn't finding any cause I was looking for truck wheels but I'd rather just get them from you I like to help out forum members and I work 2-3 days every week around hiawassee, blairsville, and hayesville if that'd make it easier to meet just let me know
Bigdock 09-24-2013 12:38 PM
Thanks I guess that's why I didn't have any luck I was looking for truck wheels I'd just assume to get 3 from you or a whole set if you don't want to split them up I like to do business with other forum members if it's easier to meet I work 2-3 days every week in hiawassee, blairsville, and hayesville just let me know
markeb01 09-24-2013 01:14 PM
Those also look like the wheels found on 1970's Chevy big cars. They also switched to the 5x5 pattern, along with the big Buicks and Oldsmobiles. There may be a lot of those to pick from in your area, you'd just need to make sure the diameter and offset is what you're after.
