To line or not to line- need some opinions
I put down aluminum bleacher seating planks in the bed. I was originally planning on having it Line-Xed or Rhino lined but not in any hurry as I still have to finish fabbing a rear end piece. What do you guys think? Leave it raw or not?
http://i40.tinypic.com/x6itxs.jpg |
Re: To line or not to line- need some opinions
If its aluminum....I say polish it.
What 63 C-10 said.:chevy:
Great idea. What is the thickness of that bleacher pank?
That looks really cool the way it is. I would leave it alone unless you need the function of having a protective coating. The overall truck looks pretty killer too.
If it was my bed, and I wish it was, I'd leave it as is for sure.
I like that :thumbs:
I agree with leaving it as is. If you needed to freshen it up, you could acid wash it, but that may stain your primer. I am also curious as to the thickness and what mods you may have done to accomodate the planks. I am familar with the aluminum planking on semi trailers, but I had not thought of bleachers. The semi trailer planking is about 1-1.25" thick. |
Unlined they look awesome
wow what a good idea
I would line the sides and polish the floor.
If you were going to actually paint the truck and not just a suede job then I would and I would have it color matched to your paint.
If it has grip in it which I think it would it would be hard to polish. I say leave it it looks perfect
That was a great idea!! Looks good just the way it is. If your thinking of a little bling and the budget allows maybe have it anodized.
http://www.markstaar.com/Aluminum-Pl...-P10607MR.html That bed is friggin awesome by the way! |
if it were mine I would leave it just like it is.
That's one of the better ideas I've seen in a while. It looks great, don't mess with it.:metal:
Great thinking there! Never gonna rust either!
Thanks guys! The planks are 1.5" thick and about 9.5" wide. I built a square frame over the existing cross sills then used 18ga angle to attach the planks from underneath with
3/4" self-tappers. I will post up more build pics in the projects section later today. |
I'd say leave it. Looks awesome..
Yep! Leave it!
