HELP! turn signal install...wtf..where do they go?
2 Attachment(s)
OK so I took apart my steering column, making sure to take pics as I went. The problems I'm having are..for some reason the pics are awol and I cannot find an exploded view or diagram that show where these little jump out of somewhere pieces go. I know I'm not that much more efficient than the factory, so....HELP!! Where do they go....anybody...Pics would be so helpful but I can try to follow instructions. ANY help would be much appreciated. :hh::help:
Re: HELP! turn signal install...wtf..where do they go?
I checked out all areas of "FAQ'S" and Hilandrs' link and then some. I cannot find ANY info on where these two pieces go. I just bought the part to repair the broken blinker switch, ended up taking the whole column apart for other reasons. Does ANYBODY know what these parts are and where they go? Or do I just have to buy a whole new switch kit and wire it in?
I found These... I always point toward the Yellow Book(Factory Assembly)
http://67-72chevytrucks.com/vboard/s....php?p=4551646 http://www.gobookee.org/search.php?q...+column+repair |
OK I know where the brass ring goes, but where does the little plastic dohicky thing go????????????
First off, you need to use the right terminology!! That is obviously not a dohicky. It is most definitely a thing-a-majing... LOL
I recall having about the same problem with my son's truck, but luckily we had pictures. I will try to remember to look when I get home. Good luck until then! |
What year of truck. I just rebuilt a 64 gmc column and that plastic peace does not look at all familiar.
I'm working with a 66...you may not have seen anything like it because it jumps out of wherever it goes and bounces around...I just happened to see where it went, not where it came from. I'm about ready to consider myself more efficient than the factory...for now. The blinkers seem to lock on ok, they click off when I turn the wheel...whether or not they work I won't know until I get the truck back together again and have power going to them. Until then..if anybody knows, by all means enlighten me :thumbs:
Well, finally made it home, but cannot find the pictures. I found the ones where we took apart and repaired the one in my '60, but that is a whole different animal. If I get some time this weekend, I will pull his apart again and see.
Good luck! |
lol |
Anybody??
Protesting a little at work today, so have been digging all over the net looking for something for you. I should actually get off work on time today, so hopefully be able to take apart my son's column and get a look at it. I didn't find anything at all that even looked similar to what you have. Are you positive it is a stock column? Maybe post a pic or two of the column, and someone smarter than me could help.
I just had my 62 GMC apart and it was completely different. Sorry no help.
Those parts look familier though...I also have a 63 Nova. Maybe they are the same? If you are still stuck tomorrow I can look at the library here. They have a good reference section. |
Boxer957, I took apart my sons steering wheel last night, and it does not have those parts in it. I took pics, but didn't end up with time to get them on here. It has this in the column.
Do you have any pics of the column itself? It may have been swapped out at some point in the past, and we are barking up the wrong tree. LOL
And no problem on trying to help, that is what this forum is for! |
LOL...
Oh well, just an idea. Good luck man!! :metal: |
Well , there we have it. If it's on the internet it must be true!
Can you post a pic of your column? Those parts do not look 60-66 and I believe your column may have been replaced by the PO.
