windshield replacement
Should i get a front windshield installed from a local glass company ? Do you know if they usually have gasket instock and do they deal with the chrome trim??
I realize these are generic questions but any info would help. my gasket is deteriotated bad and starting to leak in the bottom corners plus i have a big crack in the middle |
Re: windshield replacement
I bought my gasket from Wes at Classic Heartbeat.\
He is on the site here. Most gaskets are the wrong size even though they are sold for our trucks. Buy it from him and you should be all set. I had mine done at an auto body/restoration shop. Worked out well for me. Good luck. |
Most windshield repair or replace shops do not have the people that know how to do these trucks, all windshields are glued in now, unless they have an old school person that still works for them. Its all most like an art to putting these in. Just ask around your area maybe someone knows somebody that stiil does them. Thats what i had to do and he even came to my shop to do it.
I went on line and found a company called safelite.com they came to the shop and installed mine and supplied the gasket also.
The guy that installed it let one of the wiper arms slip when he was removing it and scratched the hood and they paid for the repair. |
i looked at safe lite, they get good reviews, will probably check them out, thanks guys |
Do you have Binswanger Glass in your area? I used them to replace my windshield because they had the best price and were close to the house. They said they could get a new gasket or I could provide it. I bought a Precision gasket from GMC Paul.
All was fine and dandy, until it rained a couple weeks later. Then you could see the window leaking water on to the dash. Would you believe it took about 4 additional tries before they finally fixed the leak? It wasn't until an older, more seasoned guy at the shop itself (vs coming to me with their van) discovered that the guys left off the caulk sealer at the bottom center of the window. I guess the guys before were too damn short or lazy or both. Oh, another thing. One of the original guys opened up my doors, stood on the edge of the cab floor, and was leaning against my open door hard as he installed the glass. I almost said something, but figured it must be ok, and I shouldn't be a picky ass about it. Well, a couple days later, that door's hinge pin sheared off and the door almost fell off. Had to replace the hinge and get it all lined up again. Fun stuff. So, in the end they got the window taken care of, but I think time would really need to be a healer before I'd have them do my window again.... |
make sure there is no rust under the gasket or around it because there usually is.
My plan was to cut out the old one do some good clean up around the gasket sealing area and hit it with some etching primer and rustoleum just for safety and get one installed, Classic heart beat has a gasket , and i heard good things about it but there website is basic and i do not like not getting shipping up dates on stuff i buy and order status , i will look at GMC pauls |
