-   -   33.12 whats the correct rim with 8 or 10 (https://67-72chevytrucks.com/vboard/showthread.php?t=603465)
NASTY-LSX 11-07-2013 10:34 PM
I meant to say whats the best tire size for a 10 inch rim in 33 height
I have centerline imitations right now. with 33.12 on 16.5 tall 16x8 rim.
I am going with wheel vintiques 82 series steel wheel in a 16x10. The 12.5
tire looks kinda narrow already with the 8 inch wide wheel. What is the best tire
for a 10inch wide rim in a 33 series?? thanks.
http://i570.photobucket.com/albums/s...0808080077.jpg
http://i570.photobucket.com/albums/s...E70/smokey.jpg
NASTY-LSX 11-07-2013 11:32 PM
Re: 33.12 whats the correct rim with 8 or 10
also is it harder on the front end (bearings,axles) to run 16x10 with 33's :chevy:
Rubble 11-08-2013 01:31 AM
I ran 15x10 ris with 33s for years on my 80K20 without any axle,wheel bearing troubles.My 86 K20, had it for 3.5 years,90,000 Kms with 35s on 15x10 rims & no troubles either.Keep your bearings packed & set up right,you will be fine.
NASTY-LSX 11-08-2013 01:38 AM
thanks!!! At what point do i need to start changing diff ratio, like at 35 and larger tire??
I should be good with 33's?? without having to change gear ratio??
tgh117 11-08-2013 09:44 AM
Depends on what your gear ratio is currently. I have 3.73's in mine and that's about the lowest I would want to go with my 35's. With my past 33's it wasn't an issue.
I have always ran 8" wheels with my 12.50's with good luck, but I'd guess you would want to stay 12.50" width in order to keep them under the fenders.
Rubble 11-08-2013 09:53 AM
3.73s or 4.10s work good with 35s.My 86 runs about 2500 at 100k (62mph) in direct.I'm not a fast driver & this truck spends 50% of the time on dirt/gravel roads so it works good.I ran 3.42s behind a 6.2 two years ago on 35s but that was almost too tall.My 82 with 6.2/3.73s & 35s works good too,if I get into mud or snow,just throw it into low range. The 80 K20 has a 454/465 with 4.10s on 33s,but 3.73s might work better for it.Pulls good though..
1968vetL-71 11-08-2013 12:07 PM
You will love the wheel vintiques 82's! My 91' V30 crew on 16x10's, 38x15.5 Toyo's and they look awesome. I'm running 4.56's but with 33's you'll be fine not changing gears for DD use.
NASTY-LSX 11-08-2013 08:27 PM
Dayum, that looks great!!!! how bout some pics of the whole truck :metal:
1968vetL-71 11-08-2013 09:32 PM
Ya, I will get more pics when I get back down to my shop and prob start a thread. Been slammed lately. Good luck with ur truck, cool ride!!
olllie 11-09-2013 08:00 PM
I ran 33x12.5 15's for years on may different trucks 8"s and 10"s. Any tire larger than stock will increase wear rate on many parts and cost you mpg.
33 on a 16" will look smaller than on a 15" because you are losing side wall height to gain rim size. Also 33x12.5 on a 10" wide rim will not have much sidewall bubble, and if you air down off road you will have a better chance of losing a bead or wheel lip damage. 35" is when I would start to look at ratio's.
on your truck I would go 15x10 and 33x12.5's it would look nice. I think that 16" would be like a 305/65/16 on a 16x10, and they look skinny beside the 15x10's
just my 2c.
NASTY-LSX 11-09-2013 08:08 PM
just my 2c.
I agree 100%, but i have a 3/4 ton 8 lug. So 15's are out:mad:
olllie 11-09-2013 08:12 PM
.. my bad.. in that case, i think toyo open country is the widest looking 33x16 but they are loud and crappy. maybe a mickey t tire, going to be big bucks though.
cooper discover, maybe a decent one. never had them myself.
NASTY-LSX 11-09-2013 08:16 PM
Originally Posted by olllie (Post 6355817)
.. my bad.. in that case, i think toyo open country is the widest looking 33x16 but they are loud and crappy. .
thats what i want to avoid. gonna try to stick with a all terrain. Cool, thanks
Rubble 11-09-2013 09:47 PM
I have 15x10 8 bolt rims on two of my trucks,the 82 & 86. You have to grind the caliper a bit,but it can be made to fit.
NASTY-LSX 11-09-2013 09:50 PM
I have drums. I wish i could do 15's LOL.
Rubble 11-09-2013 10:22 PM
I have drums on the rears,the 82 had to grind the fins some.The 86 has a full floater & they fit no problem.
NASTY-LSX 11-09-2013 10:39 PM
OK, so your saying I can fit 15/10 on my truck with 8 lugs???
If so that would be awesome. Gonna do some quick research on wheels!! thanks
Rubble 11-10-2013 12:42 AM
I better clarify this first,on the front axle you will need to grind the caliper & backing plate to clear the rim.If your rear is a full floater,they will bolt right up without any issues.A 14 bolt semi float will need the fins on the drum ground down a bit.It's not the ideal set up,but I got a real good deal on these 15x10 rims so I made it work.My 86 had the 15x10 8 bolts on it when I bought it.Sorry for any confusion before eh!!
NASTY-LSX 11-10-2013 12:45 AM
ok got you. Thanks, i did a search on 15/10 8 lug and got nothing but wagon wheels lol. not much options. Im gonna stick with 16/10. :ito:
Rubble 11-10-2013 12:55 AM
That's all I'm running is wagon wheels!! But I am cheap too! These are just work trucks so I don't need anything that nice eh..
