-   -   Blew it (https://67-72chevytrucks.com/vboard/showthread.php?t=604758)
chris1htx 11-17-2013 09:51 PM
Blew it
i blew out my inline 6, i'm now looking for a replacement motor. looking for a 305. any suggestions?
Zane M 11-17-2013 10:08 PM
Re: Blew it
Why a 305? May as well go 350 in my opinion.
chris1htx 11-17-2013 10:14 PM
Re: Blew it
I was thinking about going that route too, I wanted to save some gas by going with a 305
kalbert 11-17-2013 10:20 PM
Re: Blew it
MPG difference between a 305 and 350 will be negligible in factory form.
mexlokote 11-17-2013 10:21 PM
Re: Blew it
check craigslist, sometimes there good deals out there, i found myself a 305 complete for $150
chris1htx 11-17-2013 10:31 PM
Re: Blew it
What are some of the major changes that I'm going to need to make for this switch?
mexlokote 11-17-2013 10:53 PM
Re: Blew it
2 Attachment(s)
when i installed mine i installed new motor mounts, and a new flywheel also oil pan gasket,
thats about it, all wiring is almost the same,
u will need new exhaust,
power steering pump is different, mine came with the original pump for the 305 so i didnt
have to buy it,.
besides that thats about it
chris1htx 11-17-2013 11:00 PM
Re: Blew it
What did you pull that out of?
mexlokote 11-17-2013 11:02 PM
Re: Blew it
1976 Chevy silverado,
Re: Blew it
Mine is a 1982 Chevy custom deluxe
meatwagon83 11-17-2013 11:06 PM
Re: Blew it
sure go 305! 6 cyl power with v-8 mileage
rollin thunder 11-18-2013 12:10 AM
Re: Blew it
I pulled my factory 84 250 L6 with a 3 speed manual tranny and put in a 74 305 just used the motor mounts and wiring harness out of the 74 ( everyhting plugged in perfectly). the flywheel and bell-house bolted up perfectly from the L6 nothing else needed to be changed just hook up and go.
on a side note my truck had no power options(brakes,steering etc..)or a/c so only had min to hook up.
TheBlueBomber 11-18-2013 09:37 AM
Re: Blew it
305 is a good motor. Not as powerful as a 350 but a good motor none the less. My truck had one (305) swapped in before I got it and right now im focusing on tightening it up/fixing leaks but in the long run I am building a vortec 350. It's all about what you'll be using it for.
What will you be using your truck for?
TheBlueBomber 11-18-2013 09:39 AM
Re: Blew it
Your in Texas so hills shouldn't be a problem... 305's HATE hills lol
motornut 11-18-2013 10:13 AM
Re: Blew it
I'm using a stock 79 2B-305 (some carb issues,not block)
runs great otherwise
i've abused a few over the years,depends how they were maintained too
check harness wire length,and wire spot in harness
chris1htx 11-18-2013 11:33 AM
Re: Blew it
I'm mainly gonna be using it on the weekends. Does anyone recommend a 305 crate? I don't want to spend 2 to 3 thousand on an engine but 1,500 wouldn't be bad. I figure I would be spending that much money fixing up a used engine
school boy 11-18-2013 12:11 PM
Re: Blew it
a 305 or 350 will both be a bump up. both engines will produce better torque bands which you will enjoy. it would be nice to use a 350 vortec but its not as plentiful as the pre 96 model. the vortec 305 isn't much different than the previous models. as for a crate engines, 305's are well priced and the tbi 350's are in the 1200-1500 range. I do suggest a full tune up if you go with a used engine
TheBlueBomber 11-18-2013 12:19 PM
Re: Blew it
^what school boy said
chris1htx 11-18-2013 12:20 PM
Re: Blew it
Do you guys recommend a crate to get?
SCOTI 11-18-2013 12:30 PM
Re: Blew it
Have you searched the classifieds here on the board? I recall 2 different sbc's that were listed recently for around 1K.
chris1htx 11-21-2013 10:07 AM
Re: Blew it
I'm still doing some searching but haven't had anything to my liking. Craigslist, eBay, classifieds no luck. The search will continue...
Green Hornet 11-21-2013 10:57 AM
Re: Blew it
I have don this swap many times, I always found a good running donor car and used everything from that. Pulled engine as complete as possible and slid it in.
martin_81 11-21-2013 11:01 AM
Re: Blew it
you can have great gas mileage/hp if you go with a ls swap. a 5.3 will be perfect. i screwed up on no going that direction
gramps77 11-21-2013 05:21 PM
why not swap in one of these
GM warranty and everything.
BRAND NEW
http://www.summitracing.com/parts/na...7353/overview/
Cant beat em. Well, you can, but not by much.......
Green Hornet 11-21-2013 06:07 PM
Re: why not swap in one of these
BRAND NEW
Thought about that as well but he has a 6 cylinder in it now, he would have to come up with all the mounting brackets for the front of the engine as well as engine mounts, intake, carb, exhaust and what not. I think to do the V-8 swap you are better off economically with a donor V-8 vehicle. GM crate engine would be the best choice shy of building your own if it was already a V-8 small block.
