How do I brighten a 70 Grille?
Hey guys,
My dad has a nice grille for his truck thats very dull with scratches. Is there a way to brighten it up?. I tried oven cleaner - didn't work. Does anybody know of a product or steps I need to take?. Thanks |
I have played with spray on oven cleaner and scotch bright pads.... Try out the technique on your light bezels first...there is a lot of scrubbing to get it shinny. Then you have to put a clear coat on it.
I've tried this in the last week or so and it is a lot of work. Soak the parts in liquid draino overnight. The anodizing washes off and the you can polish to a high luster. Looks cool though.
Did you polish it wish aluminum wheel polish?. Did you use a buffer or by hand?
ttt
------------------ http://hometown.aol.com/racedvl/racedvl69index.html Woodstock,IL.northwest of Chicago It's not what you buy, it's what you build!! I did not climb to the top of the food chain, to become a vegetarian. For some pics of my truck. |
Eastwood sells a stripper that will remove the coating and then you will have to sand it with a fine grid sandpaper then buff and not with your hand.good luck!
------------------ BIG ORANGE 1971 SUBURBAN 1970/90-Little Buck's Truck (ONE DAY) USED TRUCK PARTS 4 SALE |
I have this polishing compound from "Michiana" polishing in Indiana. Bought it at a swap meet and it works fine by hand but would be quicker with a polishing wheel. I mixed up some draino last night and let it sit too long. Made teh aluminum a little thin. Pay attention on how long you let it sit if you use crystals. I let the premixed liquid plumber sit overnight and it was ok.
this is interesting to me as I like to play with parts restorations. I never heard of the draino thing before though . how many gallons does it take to soak one of those huge grille shells in though and did you buy a big tub to put it in? do you think it would work to soak a rag with it and lay it on the grille a section at a time? thanx , DAVE
Have you tried a can of Never Dull? That is what I have used for years. It takes a bit of elbow-grease, but usually turns out ok.
In case you don't know, Never Dull is in a blue can, inside is basically full of cotton that is soaked with some sort of chemical. You just pull out a wad and get scrubbing. It works awesome. Reid ------------------ Sylvan Lake, Alberta, Canada 1970 Chevy C20 Custom Camper #s matching 402BB Turbo 400 trans. Air conditioning, power steering, manual brakes. 73,600 Original Miles!! |
How hard is it to apply the clear coat, what kind of materials are needed?
Dave,
In an answer to your question on part size, I have not done a grill shell yet but don't see why a rag soaked with the solution would not work. For long pieces such as the front fender spears, I put them in a 2" piece of PVC with a cap on the end and fill the pipe with solution. Draino is only $4.50 a can at Wally World and makes quite a few gallons. If your time is worth money, it definitely is faster than sanding. I used to glass bead blast the anodizing off but that lead to a lot of sanding and prep before polishing. Let me know how you like the process. |
Here's one I "fixed up". It had the usual dents & dings, as well as a nasty series if creases along the top edge. I was able to knock all the dents out and clean up the hammer marks using 220 sandpaper. I then used 320 to get out the 220 scratches, 600 for smoothing and ended up with 1500 grit to get a nice sheen. I finished it off with 0000 steel wool. It's now ready for the black lettering & accent stripes. Took some time, but I'm pleased with the end result! Lee
http://www.freephoto-i.net/users/wlee/Grille.jpg ------------------ 1969 Custom 20 Longhorn 1970 CST 20 Fleetside 1950 Plymouth Special Deluxe 1991 Jaguar Sovereign 1992 Mazda Miata 1969 Triumph Bonneville 1964 Harley Sportster |
Looks great!!!!
| All times are GMT -4. The time now is 06:35 AM. |
