-   -   Anybody using the LMC power windows? (https://67-72chevytrucks.com/vboard/showthread.php?t=609265)
1970/327/c10 12-25-2013 05:05 PM
I wanting to get some power windows for my pickup and was wandering how good the power windows from LMC are? :smoke:
eldogg 12-26-2013 09:23 AM
Re: Anybody using the LMC power windows?
Check out Nu-Relics. http://nu-relics.com/index.html
Razorbacker 12-26-2013 10:01 AM
I have the LMC kit installed on my K10. They were already installed by the PO and I thought it was pretty cool my truck had power windows.
Well shortly after I purchased the truck the passenger side motor failed. That's when I found out LMC does not have any spare parts support for the product they sale.
I would not recommend LMC's kit, cheaply made, the electric motors are weak and LMC Customer Service will be absolutely no help if you have a problem down the road.
1970 CST Short Wide 12-26-2013 01:08 PM
http://www.a1electric.com/catalog/cat_chevtruck.htm
These are the ones I installed. Very easy to do and work perfect.
I highly recommend them
cheyenne shortstep 12-26-2013 05:30 PM
I also recommend A1 electric windows, after 15 years on my daily driven '72 the only problem I have had was one of the switches went bad. LMC sells JUNK and nothing but JUNK.
Wrenchbender Ret 12-26-2013 06:06 PM
I put the LMC kit in a 63 I used to have. It worked good. It was a lot of work installing it. It uses the original regulators so the mech. needs to be working freely or it will put excess load on the motor. I agree with the other guys, the A1 is a better setup if you want to spend a little more money. I used the A1 in my 70.
1970/327/c10 12-26-2013 10:05 PM
Thanks for the info. I was watching videos on youtube and i didn't like how they installed. I will probably go with the nu-relics when i get around it.
bonnieclyde100 12-26-2013 10:16 PM
here is another option if you have any fabrication skills and need to save a little money
http://67-72chevytrucks.com/vboard/s...d.php?t=604386
1970/327/c10 12-26-2013 10:34 PM
You are a life saver. I did not want to spend 300 on those. I found me a project to do now. Thank you
bonnieclyde100 12-26-2013 10:52 PM
your welcome let me know how it goes , pics would be good to
1970/327/c10 12-26-2013 11:16 PM
will do, wouldn't happen to know of a good wiring kit or diy kit that i could make that looked good.
bonnieclyde100 12-26-2013 11:40 PM
found one on ebay and im sure you can find alot more if you look a while
http://www.ebay.com/itm/12v-Universa...-/141079053628
bonnieclyde100 12-26-2013 11:44 PM
here is another site that has alot to choose from
http://www.a1electric.com/switches.htm
1970/327/c10 12-27-2013 01:26 AM
thanks, now I just have to get in gear and get it made
