454/TH400 install questions
I have done some research on here about the engine perches, and I think what I have figured out is that the current perches I have in my 66 C20 that held a SBC 350 will work for the 454, but will have to be moved to the forward set of holes. Is this correct?
Also, I pulled out the engine and SM420 yesterday, and from what I understand, the SM420 trans crossmember will have to be removed and a different crossmember installed further back. Is this correct? I will figure out the placement of the crossmember when I have taken delivery of the engine and transmission. Can my SM420 crossmember be modified to work easily or is it just too much hassle? I am currently without a welder, but looking to purchase one before too long. One last question on tips of how to remove the SM420 crossmember. It looks like I can get to the lower rivets easily enough, but the uppers may be an issue. The cab is still on the truck. Planning on a grinder and serious hammer blows to get the rivets out, and drilling if necessary. Any hints? |
Re: 454/TH400 install questions
I put a 396 and th400 in my old '63 years ago. Used the forward set of mounting holes for the motor mounts and a short water pump accessory drive setup. I had hardly any clearance between the firewall and the valve covers with stock height valve covers. My truck had a powerglide so no 4 speed cross member to deal with. I have seen guys just cut the off flush with the edge of the frame with a swazall. It looks like s**t but its easy. For the trans cross member I used one from a 70s suburban.
Trans crossmember is not a problem, get any crossmember from an auto, `73 to `87 truck or suburban, remove yours and bolt in the donor where needed.
The motor mount brackets from the rear location will not bolt up correctly in the forward location. For the forward location you need the brackets for a '67-'72 with a small block. Those are designed to bolt into the forward location. Or if you wanted to go in between those locations, get yourself a set of the '68-'71 big block brackets and mounts. Alternately you could go with the better '73+ motor mounts, but you will want the motor mount brackets from a '73-'87 C20 or 30.
For a trans crossmember you just need an auto trans crossmember from a '63-'87 truck or Suburban. You'll just have to drill the bolt holes. |
Thanks for the replies. I will have to start doing some looking. RockAuto has some dirt cheap motor mounts, so I think I will replace those as well. Wish they had the perches and crossmember, it sure would make it easier. Think I'll go with the 73+ BB perches, and I may have to do the butt ugly Sawzall method on the crossmember if I can't get the rivets out of the old manual crossmember.
If you remove/drill out the bottom rivits you might be able to get a longer drill bit and drill out the upper by going through the lower holes. I put a BBC in one of my 65's. I used tubular engine mounts that I got from Truck and car shop but I also cut the firewall for valve cover clearance so I could use the rear holes. I had to trim the upper frame rails for the new perches but you have to do that with the later model ones also. My thread is in my sig.
