Can you put a sport bumper on a one ton?
My dually has a step bumper on it that doesn't look bad but I'd really like to put a sport rear bumper on it but I don't know if it will bolt up to my frame or if ill have to modify the brackets. Any info is appreciated.
Re: Can you put a sport bumper on a one ton?
blazer brackets, modify as necessary
I'm thinking it will take the pickup brackets, just like any other 1/2 or 3/4 ton pickup. The uniqueness of it being a dually is all forward of the rearmost part of the frame. K |
Standard truck brackets is all it takes for the no hassle install. Blazer/burb brackets can work w/modifying.
Truck Brackets.
Same brackets as 1/2-3/4 ton
Bolts on and looks good There are a set of brackets for 80.00 on the 73-87 parts board... You can buy the bumper (ask for a blazer /suburban) at any bumper shop or body shop supply |
Thanks guys, I didn't know if the frame was the same back there or not
