-   The 1947 - 1959 Chevrolet & GMC Pickups Message Board (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=13)
-   -   how to remove window glass (https://67-72chevytrucks.com/vboard/showthread.php?t=611716)
rollinrooster 01-12-2014 09:42 AM
I have my windows removed from the doors, just need to ask the experts how to remove the glass from the metal around it. Thanks in advance. ;)
oldcouple 01-12-2014 03:53 PM
Re: how to remove window glass
Heat, WD-40, dead blow hammer, dull screw driver, take your time.
solidaxel 01-12-2014 04:02 PM
Is the bottom track removed from the glass?
Jack Guzman 01-12-2014 04:41 PM
Chevy manual says to use gasoline. I tried it and it works fine.---Jack
rollinrooster 01-13-2014 09:22 PM
Not sure... I believe it is still attached. I have metal all the way around the window.
youngrodder 01-13-2014 10:19 PM
On mine (one peice side glass) there were (2) small screws that attatch the metal glass trim to the metal runner that is attached to the bottom of the glass. Once the screws have been removed you can slide off the metal trim.
Make sense? If not I can get you a pic.
Marc
solidaxel 01-14-2014 12:39 AM
Marc
Thanks, that is where I was going with this!!
When you get the bottom separated from the trim part try the gas or laqure thinner, maybe a piece of hard wood and a malett if it gives you trouble
rollinrooster 01-14-2014 02:06 PM
Got it...Thanks Guys
