Need Help - At end of my rope with '94 K2500
Have a '94 K2500 that I love, but it has something funky going on, and I no longer trust it. When I start it, it will chug for 10-15 seconds when I give it gas. After that, it clears up and runs fine. Sometimes it does it every time I start it during the day, sometimes it only does it the first time I start it in the morning. Now, it has developed an issue where I will be sitting at a stop sign, and go to take off, and it will fall flat, like its getting no fuel. Then it'll catch up and be fine.
I have thrown money and parts at it. New plugs, wires, the timing chain was bad so fixed that, and the shop I use has a parts vehicle, so every sensor has been swapped and tested. New fuel filter and cap and rotor also. Probably other stuff I have forgotten. Compression was tested and one was a little low, but the mechanic didn't feel it was enough to cause the issue. Love the truck and don't want to buy a different one, but it's my main farm truck and needs to be reliable. Any ideas? TIA |
Re: Need Help - At end of my rope with '94 K2500
Seems like fuel pump.
I thought so, too, but it has been tested and supposedly tests fine. I've thought about changing it anyway, but I'm a little hesitant because I've done a couple and they always turn out to be a real pain. Probably will be my next move, though.
Fuel pump brother! My 89 had a similar issue at first it'd run fine but give out at higher RPMs an thought maybe something with the motor an it was nothing then one day in 5o'clock traffic it dies causing a huge back up an had to get it towed. Dead fuel pump. Was the original one in 127,000miles at that time. Got one from Napa an is been 3yrs an the truck has 132,000 on it an runs great!
Intake manifold gasket is crossed over a little or TB base gasket is leaking or IAC is failed. Also if the CTs fail and the ECU thinks the motor is running too cold it over fuels to help save the motor. Those things and bad fuel pressure are all that can cause this truck to run like that. I just typed a book about how to trouble shoot it on this other thread, check it out. I fought this problem for most of a year, I'd completely had it when I finally figured it out.
It's fuel pump. Had the same exact thing happen to me.
| All times are GMT -4. The time now is 08:04 AM. |
