Will this fuel sending unit work?
Using a fuel tank out of an 87 G10 Chevy Van. The fuel sending unit is bad, and I'm going to buy a new one. Just want to make sure this one will give me a accurate read out when using the original fuel gauge.
The new one's specs are: Resistance When Empty (Ohm): 0 Ohm Resistance When Full (Ohm): 95 Ohm |
Re: Will this fuel sending unit work?
I believe you need a 90 ohm sender.
http://67-72chevytrucks.com/vboard/s...d.php?t=500533
here is a thread on ohms 4u |
I used a 0-95 ohms unit out of a k5 blazer. Tested in truck and works perfectly.
