Longer wheel lug studs and spacers.
Hi,i,m running Boss 338 20x10 with 275/40-20 rear on my -83 GMC C1500.Should need a little more space between bed and tire.
Have mailed lugman in Florida but no answer,any tip where to buy a kit with extended studs and 3/8" thick spacers ? |
Re: Longer wheel lug studs and spacers.
In America we usually do not do those types of Mods so there are not any kits I am aware of. If they are done it is usually to European cars because they use bolts instead of studs. Also pulling studs is a long process because of the dis-assembly process to do it.
Try www.Summitracing.com or www.Jegs.com They have longer wheel studs for racing, and there maybe the length you need in there. |
I had a small wheel spacer on my truck and I was looking for longer studs a while back, couldn't find anything.
Ok,thanks for your answers.Was thinking to buy this model:
http://manton.se/3-thickbox_default/...c6-spacers.jpg |
| All times are GMT -4. The time now is 06:03 AM. |
