72 k10 odometer doest work right
My truck odometers been working fine but today it was 76,666 and 9 tenths and when it went over it never moved to 76,667 it said 76,666 again. I am not that sure on what to do, speedometer works fine. The tenths on the odometer works fine also.
Re: 72 k10 odometer doest work right
It sounds like your odometer drum is broken. The only way to fix this is to remove the gauge cluster from the truck and disassemble the cluster.
I can repair this for you with a good used odometer drum. If you have the ability to remove the speedometer head from the cluster, you can send me just the speedometer head and I can repair it. Or you can send me the whole cluster, either way is OK, it is just less shipping if you send me just the speedometer head. Let me know, Take care, Tom |
