-   -   greasing new fuel pump (https://67-72chevytrucks.com/vboard/showthread.php?t=623536)
Squareforceone 04-03-2014 12:47 PM
hey i'm about ready to put a new mechanical fuel pump on my 350 and have heard to grease it first. Do you guys do this and if so what kind of grease do you use. Thanks
ont_guy_38 04-03-2014 12:54 PM
Re: greasing new fuel pump
I have always filled the inside with bearing grease, not sure what it does or if it is needed. Something my dad told me and have just always did it.
ont_guy_38 04-03-2014 12:55 PM
The grease also helps hold the gasket on till you get it mounted.
MJN 04-03-2014 01:15 PM
The only thing I've put grease on is the pump push rod to help hold it up inside the engine while installing the pump. Engine oil should do the lubricating that is required.
Krwright 04-05-2014 09:37 AM
Grease doesn't break down in engine oil. I hope you mean lubriplate or assembly lube.
