-   -   Clutch pedal removal (https://67-72chevytrucks.com/vboard/showthread.php?t=625696)
scrappy's 69 04-19-2014 07:28 PM
I am new to posting on this forumn, and appreciate any help in advance. I have a 69 C10 that was converted from three on the tree to automatic in the floor and the clutch pedal is still in thr cab. I have looked at trying to remove and do not see how it comes out, any ideas?
Maladd 04-19-2014 08:50 PM
Re: Clutch pedal removal
I'm no certainly not the one to give mechanical advice, but if it is the same as a 1968 it is very easy. I did the same thing myself just following the advice on former threads here. I'll try to copy some links for you!
http://67-72chevytrucks.com/vboard/s...d.php?t=303897
Hope that link works for you!
scrappy's 69 04-19-2014 08:55 PM
Thanks, this confirmed my suspicion thta it will not be easy.
jordanblea 04-19-2014 09:01 PM
You could cut it out....
Maladd 04-19-2014 09:02 PM
No, it was pretty easy even for me. Think 15 minutes tops. The hardest thing was figuring out where everything was in relation to the photo in that thread.
I wouldn't get discouraged, just give it a shot :-)
Maladd 04-19-2014 09:04 PM
Wow, hadn't read that thread in a while, posts make it sound much harder than it is! Definitely easier than cutting it out IMO.
