-   Blazer and Suburban Stuff (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=199)
-   -   MT Needed: These grommets for rear CST trim panels, anyone have spares? (https://67-72chevytrucks.com/vboard/showthread.php?t=625957)
DeadheadNM 04-21-2014 05:07 PM
I'm installing repro rear CST trim panels in my 72 K5 and need three screw grommets (see pic). Does anyone have junk panels they can harvest grommets from? Thanks, Pete
Sandemonium 04-22-2014 12:29 AM
Re: Needed: These grommets for rear CST trim panels, anyone have spares?
I have three I can send your way.
PM me your address.
Bob
gmclonghorn 04-22-2014 01:51 AM
Who makes a good repro rear cst trim panel? Just getting ready for my restoration
nobolt 04-22-2014 11:18 AM
Pete,
are they brass?
I have gotten similar grommets at Boaters World (now defunct) but you may have some luck at West Marine or some other boating site.
good luck!
DeadheadNM 04-22-2014 07:49 PM
PM me your address.
Bob
Sending PM your way. Thanks Bob!!!
PM member Truckseats (Tim) he can set you up. Believe he has a thread that shows examples that a search should turn up. The quality is actually better than OEM. The repros use melamine instead of cardboard, the stitching is real and done by hand (not embossed pseudo-stitches), and the scrolling is deeply embossed. The padding is a little thicker so the panels are a little "puffier" than OEM. Mine came from Brothers because I didn't know that Truckseats could supply these. The walrus grain vinyl is similar.
Originally Posted by nobolt (Post 6640789)
Pete,
are they brass?
good luck!
Thanks! Not brass appear chrome/stainless. NAPA has a very close match for the chrome trim screws. The OEM screws are self tapping and shorter.
nobolt 04-22-2014 08:30 PM
I looked at a few marine sites today. the only ones I came across that were close to yours had a nickel plated finish over brass.
DeadheadNM 04-22-2014 09:02 PM
Dave - Post a link(s) when you have time. Thanks.
IronCanine 04-22-2014 10:21 PM
This looks close to me...simple google search. You may have already seen them. But it looks like you can get them in brass, nickel, or black.
http://www.seattlefabrics.com/gromsn...her%20Grommets
DeadheadNM 04-22-2014 10:56 PM
Those look good!
DeadheadNM 04-23-2014 12:01 AM
Just thought I'd point this out. The diameter of the OEM grommets is larger on the outside than the inside. Consequently, you can drill a hole in the new panel the diameter of the inner grommet edge and then just pop the grommet snugly into place. The pic above shows one installed in that manner.
Sandemonium 04-23-2014 10:35 AM
I was originally planning on using the 00 grommets and the tool to spread out one end to match the factory ones, but now I am debating using Velcro to avoid having screw holes.
DeadheadNM 04-23-2014 11:06 AM
Velcro is a great idea especially for the double wall folks who need to remove these to remove the top.
DeadheadNM 04-29-2014 11:29 PM
Bob the grommets arrived and are exactly what I needed. Big thanks!!!!!!!!! I really appreciate the help. Pete
Sandemonium 04-30-2014 01:12 AM
Glad you received them and can use them.... Happy to help.
Bob
