-   LSx Swaps (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=206)
-   -   DBC Gas Pedal Options (https://67-72chevytrucks.com/vboard/showthread.php?t=628172)
uxdesigner 05-09-2014 12:45 PM
Recently got my 5.3 Vortec installed and running. First crank and she fired up, what a relief! Next step is the gas pedal, since I have a DBC engine and a 70 C10 I'll have to replace the pedal it currently has.
What are my options?
  • 71 - 72 pedal?
  • Aftermarket pedal (part number)?
  • Modify exitsing?
Low Elco 05-09-2014 03:21 PM
Re: DBC Gas Pedal Options
I'm using an 04 yukon pedal. Flat sheet out of the factory holes, drill and tap for the DBC pedal, chop the DBC and Factory pedal in half and weld 'em up. et 'voila!
Matt Cramer 05-09-2014 04:35 PM
I used the stock pedal on my '72 Chevy with a mountain bike brake cable for the cable.
uxdesigner 05-09-2014 05:58 PM
Any pics? Much appreciated
JNJchev77 05-09-2014 06:14 PM
Lokar makes a nice accelerator pedal that'll bolt right up...
http://www.lokar.com/product-pgs/new...10-pedals.html
uxdesigner 05-12-2014 01:30 PM
Thanks for the link, a little high priced for the pedal so I think I'm going to hit the part yard soon and try and find a later model pedal.
wgeyer88 05-12-2014 03:06 PM
I used the LFD 71/72 pedal adapter:
http://67-72chevytrucks.com/vboard/s...d.php?t=371099
With LS1Nova's cheap throttle cable solution:
http://ls1tech.com/forums/16783919-post34.html
Matt Cramer 05-13-2014 12:23 PM
None in the cab, but here is the bracket I made to attach the cable at the throttle end as the manifold setup was originally DBW.
