-   -   Easy Fuel pump question...Help Guys! (https://67-72chevytrucks.com/vboard/showthread.php?t=62935)
nejeff 07-31-2003 08:23 PM
I am replacing a stock 72' 350 4-barrel and it has two lines going into the bottom of the fuel pump. The motor I am replacing it with is a 72' also , a 307 2-barrel and it has one line feeding it with fuel.
What the hell do I do with the second line and what is it their for?
I need help guys!!
nejeff 07-31-2003 08:45 PM
ttt---help!
ttt---help!
nejeff 07-31-2003 09:02 PM
Guys!! I really need to know what's up!! Please let me know
my new 72 07-31-2003 09:12 PM
One is a return line. Just plug the return line and run it.
jef5150 07-31-2003 09:20 PM
the fuel pump should have 2 places to connect lines.......1 line goes to the gas tank [inlet] and the 2nd line [outlet] goes to the carb,,,,,,,,,
nejeff 07-31-2003 09:23 PM
Mine has three total...two on bottom and one going to the carb. WHich one do I plug if one of them is the return line?
Thanks guys
Jeff
lukecp 07-31-2003 09:41 PM
Just run the fuel pump for the 350 on the 307...it should bolt right up. It has been awhile since i have replaced a fuel pump, but i am pretty sure all of the lines have different sized fittings so you can't mess them up. If you want to use the 307 pump, the smaller line going back towards the tank is the return line, plug it.
lukecp 07-31-2003 09:46 PM
oops...i re-read your post, you are hooking it up to a 2bbl carb....i believe that is what determines the difference in the fuel pump, the 4bbl pump has a return line, and the 2-bbl dosen't. In that case, just plug the smaller return line....OR
Put your 4bbl intanke and carb on the 307 and run the 350 fuel pump. Gotta have a 4bbl :)
Stocker 07-31-2003 10:02 PM
Just checked - my OEM Q-jet 350 has 2 lines... :)
StingRay 07-31-2003 10:36 PM
If it's a 72 307 don't try that 4 bbl without the 350 heads as well. the 72 307 has tiny little ports and won't be the effort of a 4 bbl swap without better heads.
lukecp 07-31-2003 10:37 PM
When mine was a OEM Q-jet 350, TH350 truck, it had 3 lines, one going to the carb, and two going from the tank to the pump :)
nejeff 07-31-2003 10:52 PM
Thanks alot guys!
I think I'll just swap the fuel pumps and save myself from having to think too much!
Really, thanks for all the info
Jeff
my new 72 07-31-2003 10:59 PM
Oh yeah, I forgot to mention that the bottom of the pump is market inlet outlet, and return.
smokekiki 08-01-2003 08:55 AM
The return line was there to circulate fuel around the inside of the pump.This was to keep the pump cooler to prevent vapor lock.
Gordo 08-01-2003 09:20 PM
You can swap pumps but you may find the outlet from the pump to the 2 bl carb on the 307 takes a 5/16" fuel line and the 350 with the 4 bl takes a 3/8" line. So you will have to fab the two together.
Z-72 08-02-2003 09:18 AM
I just had that problem myself, had bad problems with vapor lock until I put the two line pump back on. No problems now.
nejeff 08-02-2003 11:17 AM
Thanks guys!
I am going to try the stock 307 pump first and then switch if I have trouble. Thanks for all the information!
Jeff
