Why is my truck such a pain
The thing can't near do anything right it's one thing after another a new alternator new starter new everything and now I'm told c10s can't pull a whopping 6500 pounds! Well what the heck is a c10 good for other then sitting flat and stupid!Heck I can't even lift the thing!
Re: Why is my truck such a *****
Well, sir, it is a 32 1/2 year old truck....
bs, I've towed that much with mine.
They don't make 3/4 ton and one tons for nothing. You use the right tool for the job....
Concepts of a 1/2 ton changed in the last 15-20 years. Back then a 1/2 ton was a 1/2 ton.
Today you can get a 1/2 ton to almost tow as much as a old school Crew cab dually. |
Then sell it and get something bigger...
It is a safety issue. It can pull the weight, but can it stop it?
If an alternator and starter were all you put into your C10 you are doing very well. Prices for rebuilds or even new AC Delco on those parts are cheap. A 1/2 ton can haul a lot if it is geared properly, but as has been said, stopping and handling with the relatively lightweight suspension and frame are an issue.
In my mind, a 1/2 ton is built more like a car, and a 3/4 ton is heavier all the way around - from the front suspension to the rear axle. I think it actually weighs about 1000 lbs. more empty with all that gear on it. Of course, 3/4 ton gas mileage is terrible compared to a 1/2 ton. |
The weight I would see a decent truck to pull is 6500 pounds to 8000 I plan to have a reliable truck that can haul jetskis and crap around.ahell the newer v6 Chevy models pull more weight this is a joke! |
Re: Why is my truck such a pain
We'll I wouldn't want a 3/4 ton I would want a 1 ton at least what the hell can a 1 ton do other then waste more gas to load albertsons groceries!
The weight I would see a decent truck to pull is 6500 pounds to 8000 I plan to have a reliable truck that can haul jetskis and crap around.ahell the newer v6 Chevy models pull more weight they 6500 pounds this is a joke! |
Haha to the mod that fabricated my original post.. I knew you would! It was funny I wanted everyone to see it have some humor for this forum is funny?
Ive had to edit several posts in this thread due to non family suitable language. This is amazing because it is a pretty easy topic to discuss without using stuff that is not family friendly. If I have to edit this one more time it will be closed
For a reference, I had a 2004 GMC Sierra, long bed, regular cab, 4x4 with 5.3 V8 and 4L60E automatic transmission. Great truck. I loved it for 7 years, maintaining to perfection, but using it as well. 180K miles, towing, plowing snow and commuting.
The only thing it could not do well was tow. It was rated for 8900lbs, but my 5000lb trailer loads would make the chassis flex, rear suspension squat and generally wallow in turns. It had plenty of power, and adequate braking, but the chassis was not enough. I tried a few upgrades with some positive results, but it never felt right. Upgraded to the 2500HD in 2012, and its a world of difference. Its also almost 2500lbs heavier! And gas mileage is terrible. But towing is easy-peasy! The lesson is tow/load within the legal ability of the truck and to where you feel comfortable. |
If you plan to lower your truck just use C30 parts. |
It like a have my cake and eat it too thing not usually gonna happen. What kind of boat? it should have no problem towing a normal boat and jet ski, i tow with my 85 k10 alot and it does fine. As for replacing alternators and starters that's nothing compared to a new truck payment that will also break down sometime or another. I am way ahead from driving older stuff vs car lot new i haven't had a truck payment in years and my trucks don't require that much $$ to upkeep.
You might want to fix your truck before you start a thread about the lack of towing capabilities of ALL square-bodies.
Here is mine working, no problems at all towing or braking. It was a lot less then buying a brand new 2014 Dually. Attachment 1260410 Desert |
