-   -   1976 c10 with a 1974 grille (https://67-72chevytrucks.com/vboard/showthread.php?t=630376)
jwa76fleetside 05-27-2014 05:52 PM
i believe the latch mechanism is different. Does anyone know what parts I will need to install the 74 grille on a 1976?
KrazyRay 05-27-2014 08:04 PM
Re: 1976 c10 with a 1974 grille
The easiest way is to get 73-74 hood latch, center grille support, and the outer grille brackets. I sell a bunch of them. Some guys just use the outers and improv the rest.
jwa76fleetside 05-28-2014 03:09 PM
how can i purchase these parts from you?
jwa76fleetside 06-13-2014 01:36 PM
Does anyone know where i can purchase 73-74 hood latch, center grille support, and the outer grille brackets? LMC doesn't carry.
83GMCK2500 06-13-2014 02:25 PM
Should be a set or two at Yank-A-Part Auto Wrecking in Poulsbo. When I worked there I pulled a couple sets. They may also still be parting one or two '73/'74 trucks. They try to keep quite a few squares around, but I know they just finished a crush, might be lean now but they'll find more.
bigblock73 06-13-2014 03:15 PM
There are a couple in the classifieds here right now.
1774btcrew 06-13-2014 06:55 PM
I have some
