Parking brake levers question
Guys,
I'm in the process of getting the parking brakes working on my '65 C-10 and am needing the levers that attach to the rear shoes. They're gone on mine. I have a factory rear end out of a '71-72 C-10 and the levers are still on it. Does anyone know if these will work? If not, does anyone know if they're available in the aftermarket? I've looked through some of my catalogs, but haven't seen them listed. Any help is much appreciated! Thanks in advance! |
Re: Parking brake levers question
break out yer google foo....I've dug them up at Oreillies before .... for starters....
Strut, rear, drum brake http://www.oreillyauto.com/site/c/se...make=Chevrolet hold down kit http://www.oreillyauto.com/site/c/se...RWD&vi=1322682 cables for l/r long and short wheelbase http://www.oreillyauto.com/site/c/se...RWD&vi=1322682 I'll keep looking but I for 99.9% for sure recall seeing the levers you want available thru oreillies.....just a matter of runnin it down. |
I think this is it....
Left Rear http://www.oreillyauto.com/site/c/de...1312&ppt=C0064 Right Rear http://www.oreillyauto.com/site/c/de...1312&ppt=C0064 Spring kits http://www.oreillyauto.com/site/c/de...1312&ppt=C0064 |
Thanks for the replies, guys!
Sharps, I don't think that those levers in the self-adjuster kits are the ones I'm looking for, but I may be wrong. The levers I'm looking for are actually held to the rear shoe on each side by a c-clip. I'll try to find a diagram and have a look, since I'm at work right now and can't take the brakes apart until I get home this evening. Thanks again guys! |
Okay....you want the heavy duty levers that attach to the top of the shoe and then to the cable. Expanders or some such.
The rear drum brakes and kits are pretty much the same thru the late 70s. If the set up you have are the 11x2" drums, you can most likely simply transfer the emergency brake levers to your 65. One pretty simple indicator of whether they are the same will be the shoes....my guess is 65 rear shoes are the same...as such, levers will most likely be the same as well as their attachment points. |
2 Attachment(s)
is this it?
Holy Crap! Thats it! Betcha....
Thanks again, guys!
pimpston65, yes, that is it. That's a very good pic of it. I couldn't find a pic that good of it. Sharps, I'm not sure if the shoes on the '71-72s are the same as the '64-66s, but I can find out easy enough. I'm going to take them off of the donor rearend and see if they look like they'll work. My shoes are the 11" x 2"s, so it sounds like there's a good chance that they will work. Thanks again guys!! I really appreciate the quick help!! |
99.+% sure the levers you have on the newer rear are what ya need. The rear brakes didn't/don't change much. Luck.
I'll hopefully find out tonight.
Thank you sirs!! |
| All times are GMT -4. The time now is 10:52 AM. |
