Patch everything or swap cabs?
Not quite ready for a build thread yet, but the 59 GMC Short Fleet I picked up has cab cancer...Here is the cancer list so far:
As far as I know, these all have repop patches available (except the upper door area) that I can use to repair these areas. My other option is to pick up a clean cab locally, and I think I have a line on a cab that also comes with the doors, front sheet metal, emblems, grill, etc. I also need a window, and i can get that from the donor cab as well. Seems like an obvious choice to swap out the cabs entirely for $500, except... http://dshillingphoto.net/photos/Car/sDSCF5184.jpg The cab I have now is an untouched GMC interior, and granted it needs new everything that isnt metal after sitting for 30 years, the original paint is still nice, and naturally, the exterior above the rust has matching patina, including that perfect eggshell white roof that im bringing back to life by wetsanding off the single layer of blue shot over it 30+years ago. So I need to keep the original cab where I can, just basically replace the bottom 12 inches. For anyone who has done both, which path keeps the most hair in my head?
Re: Patch everything or swap cabs?
Update, the guy is selling everything except the bed and the rolling chassis for $500, so cab, doors, hood, grill, emblems, cab trim, etc. I have to pick it up on sheer principle!!
Man, If it was mine, I'd use the donor cab, and swap dashes. Lots of spot welds, but you are talking a LOT of work on that rust repair.
I need to catalog the amount of parts im getting...there is quite a bit. if i go full Porterbuilt , it might be easier to just get a bare frame to do that. That means I would have a stock chassis sitting around, and an extra cab and sheet metal...thats another truck! (= I have 5 acre taste on a 3-car garage budget :waah: |
I'm with Skymags, I'd take the best pieces of the two and make one. You will still have some usable left overs to sell to get part of your money back.
I have a 59 GMC and the cab needs a lot of work also, like you I've thought of which route to take and the thought of bringing the old cab back to glory won out. So it's patch panel time, I've never done this but am excited to repair this 59 cab.
I would personally move the good dash to the good cab and paint it before I would tackle all the body work in the floors, cowl and corners. Lots of guys have successfully did the faux patina. I just delt with a minor redo on my step and the thought of getting the whole cab tweaked is not something I would want to tackle. Guess out west we are spoiled by relatively good cabs....
But if you decide to do the body work, brace it good and get the doors aligned first, then tackle the cowl, floors and corners. |
I am having a similar dilemma. I loved the idea of having the original cab on the original frame but my cab is in bad shape. It needs floors, cab corners, inner/outer cowls, steps, and a section of the upper windshield frame. I sent the cab, doors, and some other parts to the sandblasting shop last week.
I am past debating whether or not to utilize another cab since I already had mine blasted and begun to order patches BUT I am afraid that since it was not aligned and braced before I tore it down that once I start cutting it up it will not align properly after repairs and reassembly. Any thoughts? |
i replaced 2 rear cab corners in and out, floors, hinge pocket repair, steps, rockers and front corner repairs
it would have been a lot easier to do a cab swap, but any cab around here would have been worse off than mine plus you'd need a vin plate and title for the new cab or at least cut out the vin tag area and transplant it (borderline illegal) |
I have seen lots of fauxtina as well...just never seems to look like anything more than fake. I suppose I cant avoid paint if I'm patching corners and the bottoms of doors. If I go with the bodywork, is it better to work with aftermarket patch panels or panels from a donor cab? Or no different? |
Would it be a good idea to reinstall the doors and front sheet metal before I start cutting the cab up? That way I can check the gaps and brace the cab or will the alignments be off just from having new metal. I suspect the current rotted metal is "off" compared to spec |
Mine got a complete floor, steps, rockers, cab corners, real floor lip, some firewall/Cowel patches, and a little bit of patching around the rear window frame. Was it a lot of work? Hell yes, was it worth it not having another of these trucks getting crushed? Double hell yes!
I braced my cab on the inside with the original doors on and shut with good gaps. I braced it across the door openings and across the cab with 1/2 rebar. Then I pulled the doors and got the plasma/cut off out. The only issue I've run into is my aftermarket doors fit like aftermarket doors. I bolted the oe doors up to test everthing after it was all patched up and they good... Needless to say I'm on the hunt for some good south west rust free doors. |
So I'm signing up for a MIG welding class...something tells me patching this cab is going to be an epic journey full of money and cusswords.
consider it shop time therapy :D
there's a reason mine took 8 years to make it a driver life and family get in the way... and they should |
Check out the build thread on my '57.
I posted detailed photos of all my patch panel installation and metal work. It doesn't start until post #43. |
