-   All 4x4 Tech & Off Roading (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=30)
-   -   Install Trasnfer case (https://67-72chevytrucks.com/vboard/showthread.php?t=641904)
Jamminjohn 09-02-2014 02:27 PM
Attachment 1297186HI guys,
Quick question.
I am trying to get a transfer case installed into my 72 k5 4x4.
the motor and trans are installed already, The transfer case is mounted to a cross member now sitting on the ground.
What is the easiest way to get in installed?
I have tried a trans jack, but it still seams awkward and heavier on oneside.
Any advice would be gratefully appreciated.
thanks
tommartin 09-02-2014 03:17 PM
Re: Install Trasnfer case
looks like a np203 from here. they are very heavy, best way is with some help. i used just a floor jack and made a custom cradle, and it was a pain. I would deferentially get a good trans jack to make it easy.
http://i462.photobucket.com/albums/q...psaeba1d04.jpg
http://i462.photobucket.com/albums/q...ps5fc9da34.jpg
even then, it was only a one time use because it broke after i used it.
OrrieG 09-02-2014 03:26 PM
I rented a trans jack and made a similar cradle. Floor jack gets it up, but trans jack gives you the side and front to back fine tune adjustment, a lot easier than horsing 250# around. I had my floor pan out (59 truck) so had easy access from the top too.
Jamminjohn 09-03-2014 10:11 AM
Thanks guys, I did make something last night and was able to get it on to the trans jack. I will attempt the install this afternoon when I get home from work.
Are there any gotchas when trying to install it? Is it as easy as jack up and bolt in?
thanks,
John
Jamminjohn 09-04-2014 10:34 AM
I have jacked up the t/c to the trans , but cant get it to slide over the tail shaft.
Not sure what I am doing wrong.
any ideas?
CUSTOM/10 09-04-2014 11:37 AM
Do the spline counts match up ? There are a few different set-ups.
10 spline
27 spline
32 spline
If so you may just need to get the alignment correct, and the splines lined up correctly. It's no fun horsing that heavy beast around under a truck !
Gary
tommartin 09-04-2014 01:02 PM
thanks,
John
Don’t forget the gasket or RTV between the case and trans adaptor… I forgot the gasket and had to pull the case back down.
By the way, what case and trans are you putting together?
Jamminjohn 09-04-2014 01:58 PM
I do not know, unfortunately.
I do know the trans is a turbo 350 (I think)
Jamminjohn 09-05-2014 12:25 PM
2 Attachment(s)
ok, I have got it almost all the way in. It has about an inch to go, But I can not get it in.
RPBurris 09-07-2014 12:41 AM
Not to hijack...but i just posted this question. I have an np203 and t350 that i just put fluid in after being apart for several years and fluid is leaking from the trans adaptor plate. Does this mean i need to tear it apart and put rtv between the plate and trans? son of a .....
