Front coil springs
What is the best way to determine if I still have stock front coil springs are whether they have been cut or replaced with shorter ones? Number of coil wraps?
Re: Front coil springs
Typically, you can tell if they have cut.
Evidence of torch, plasma, cut-off wheel marks. Also the number of turns, depending on manufacture, might be the same as a stock spring ... but only shorter and a different spring rate. Are they out of the frame now ? |
