-   Suspension (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=25)
-   -   Trailing arm mount location (https://67-72chevytrucks.com/vboard/showthread.php?t=644198)
hardhead 09-23-2014 05:39 PM
We are installing a 9" ford in my sons 66 at the moment and wanted ideas from some of you experienced guys on the TA mount. Before I weld the perch's on the rear axle now would be a great time to remove the front mounts and raise them if it is worth the effort. We have a stock LQ4/4L60 combo with 255/55/18 tires and it just shreds them now. Will raising the TA mount help with traction?
tinydb84 09-23-2014 06:45 PM
Re: Trailing arm mount location
Raising the front mount with increase anti-squat. It would potentially improve traction by forcing the tires into the ground. I would do it.
hardhead 09-24-2014 11:30 AM
Any other ideas while I'm there? I'm open to more fabrication if needed. I will probably build some tubular TA's that are adjustable soon.
tinydb84 09-24-2014 01:51 PM
I would probably go with a bigger tire first. 255 isn't that wide.
Here is a good read: http://67-72chevytrucks.com/vboard/s...d.php?t=326863 and Super73 is super helpful if you PM him.
