-   -   Bolt and U bolt size (https://67-72chevytrucks.com/vboard/showthread.php?t=644335)
vht 09-24-2014 07:53 PM
What size are the U bolts, front bolts on the trailing arms on a 64 to 72 chevy truck?
davepl 09-24-2014 09:00 PM
Re: Bolt and U bolt size
1310? 1330? 1350? Trans type? Rear end? 1/2 ton? 3/4 ton? 1 ton?
So far all we know is you have trailing arms and hence coils. Not enough to answer.
Honestly getting under there with a dial caliper is probably the most reliable way.
vht 09-24-2014 09:22 PM
Don't have 1 to get under or I would. I'm building a trk style susp, just curious what they used. Whichever ones had the largest.
