-   Suspension (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=25)
-   -   Changing rear tire on a 4 inch drop? (https://67-72chevytrucks.com/vboard/showthread.php?t=646098)
grs 10-11-2014 10:52 AM
Will I be able to change my rear tire on my 64 when I lower the rear 4 inches? Will I have to raise the axle, and then raise the body up from the frame? Any pics of this being done?
SCOTI 10-11-2014 02:48 PM
Re: Changing rear tire on a 4 inch drop?
You should still be able to as long as the wheel isn't extra wide w/a bunch of back-spacing.
Axle 10-11-2014 08:52 PM
No pics, but I need to do that with my Nova.
I use a truck jack under axle, and I carry a small bottle to raise up the body using the front leaf spring eye. At home I use two floor jacks. Nothing difficult about it, just get to know your lift points before you need to use them by the side of the road.
Alex.
Clyde65 10-14-2014 07:56 AM
I have a 4x4 about 2' long that I use. I use a floor jack, raise the truck up by the axle and place the 4x4 under the frame, let the jack dow a little and there I am able to remove the flat easily.
