need shifter parts
I have a '72 c/10 with a floor shift. I want to put the stock stuff back in. What years will work for parts? It is a 350auto. thanks
did you orsomeone just change the turbo 350 to a floor shift or is it a 4 speed tranny? You'll need a column and all the linkages along with a cross member for the tranny, 67-72 auto. parts are almost all inner changeable, providing you're not changing from 2wd to 4 x 4 or visa versa.A local wrecking yard has everything you need here.Let me know if I can help.
It is a 350 auto with a B&M shifter.
