-   The 1947 - 1959 Chevrolet & GMC Pickups Message Board (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=13)
-   -   Differences Chevy Vs. GMC (https://67-72chevytrucks.com/vboard/showthread.php?t=647792)
JJorgensen52 10-27-2014 10:13 AM
I'm starting to tear into the cab on my new '50 GMC, and I've run into a question regarding the metal stampings.
My truck needs the kickwell panels replaced, both sides, and on the passenger's side where the heater unit was, the rot goes all the way up almost into the dash on the inner panel.
So two questions:
1. Are the GMC/Chevrolet stampings the same? And likewise, the patch panels applicable to both.
2. Does anyone make a patch panel that reaches up into the dash? It would be about 18" high.
67GMCkid 10-27-2014 11:46 AM
Re: Differences Chevy Vs. GMC
Chevy or GMC panels are the same.
Tallest kick panel I found was from Jim Carter Truck parts, The down fall was that the floor pan I used was from Key parts and was contoured to match the their kick panel, so I cut the contour of the key parts kick panel and welded it on the Jim carter panel..
The Jim Carter Panel ends 3" from the bottom edge of the dash
mr48chev 10-27-2014 01:52 PM
You might look at the patch panels from Premier Street Rods https://www.premierstreetrod.com/det...W_Louvers.html
That should be the one for the left side. I would think that they are the same panels that they are using to build their new cabs with so they should be full size.
JJorgensen52 10-27-2014 04:16 PM
At least based on the image, that's exactly what I'm in need of.
Thanks! This board is the best :metal:
