-   The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=38)
-   -   Starter ignition problems (https://67-72chevytrucks.com/vboard/showthread.php?t=647862)
Sluggie 10-27-2014 09:27 PM
Are these years burbs prone with starter ignition problems a friend of mine has a pickup same year with same problem
LockDoc 10-27-2014 10:09 PM
Re: Starter ignition problems
No.
LockDoc
04sshd 10-28-2014 01:58 PM
what problem are you having?
My suburban has a solenoid issue, a new starter would fix it but I'm going a cheaper route. If it generates excessive heat by actuating for too long it won't engage the starter until it cools. I'm installing a ford solenoid on the frame rail and bypassing the GM one on the starter. $20 for a solenoid is cheaper than $100 for a new starter.
60sIron 10-28-2014 11:23 PM
I had to do the same. Not only on my Suburban but also my Chevelle. Summit sells the kit. It's referred to as heat soak. But this may not be your problem.
dougo 10-28-2014 11:43 PM
I had heat soak issues. The remote solenoid solved my problems. I also decided to install a high performance mini starter. But I will say - the remote solenoid was the solution in my case. I have a 454, GM manifolds (no headers)....
60sIron 10-28-2014 11:49 PM
Dough, sweet ride!
dougo 10-29-2014 11:47 PM
Originally Posted by 60sIron (Post 6896247)
Dough, sweet ride!
Thank you... Much appreciated.
