Chevy to GMC grille swap
I want to swap my original grille
Re: Chevy to GMC grille swap
To this, so I can run the 30 bar flush mount billet grille. Radiator core is the same and headlamps are the same but I know the spacing between the headlamps and marker lamps are different. What's involved in this swap. Hoping some experienced members will give advice.
Thanks |
Unbolt Chevy grille/filler, bolt in GMC grille/filler
yep just make sure you have the gmc corner markers they are different.
Am I imagining the distance between the lamps is different?
there is a difference in the distance in the marker lights but they mount directly to the grill and not the support. So just unbolt the chevy grill and install gmc grill. The filler is the same.
If you do the 30 bar grill be careful when cutting the factory insert out. Its real easy to screw up and mess up the shell. Don't ask how I know
| All times are GMT -4. The time now is 08:54 AM. |
