66 230 rochester 1bbl dual carb linkage
so i'm wanting to put dual headers and dual carb intake on my 66 230. i've found pretty much everything i need to do this (haven't ordered anything yet) but i can't find a dual progressive linkage for the rochester 1bbl stock carb, as i am planning on just buying another to go with the one on it. i want a progressive linkage to keep my low end torque.
so the question i have is: Where can i find a progressive linkage for these carbs? also.. with the exhaust, i'm planning on straight piping it out both sides and coming out at a 45 angle in front of the rear tires. is that going to be to loud in the cab to stand? i definitely want people to hear it and turn their head, but i don't want to be miserable while driving.. any help would be great! thanks |
Re: 66 230 rochester 1bbl dual carb linkage
If you purchase the offenhouser dual single barrel intake it should come with all the linkage necessary to make those carbs work. As far as the straight pipes...shouldn't be to bad. :chevy:
okay thanks. I thought it should, but couldn't find anywhere that it came with it. after looking in the reviews on speedwaymotors.com i found that it does come with a linkage, but the guy said it was junk.. hopefully he just doesn't know what he's doing and i can get it to work! and hopefully the exhaust will give the "wow" factor i want it to! some more power too! would it be beneficial to install a lump port kit? i've read that i could loose some low end torque with that, which i don't want to do..
Check out Tom Langdon at stoveboltengines.com for duals and linkage kits
Just curious. Did GM still use 230's in 1966? I thought the base engine was a 250 inline. That is true of my 66 GMC.
Thanks. My engine is dated Sept of 65 with TAT on pad. Wondered if I had a 230 since gmc used chevy engines in 66. Though, literature said gmc used a 250.
is it gonna hurt my truck if i drive it with open headers to go get the exhaust put on?
I think the consensus among most inliners with 2 carbs is not to use progressive linkage because of mixture distribution problems ,but it can work fine with a 3 carb setup,, I have a bored and stroked 261 with 3x1 and it has a progressive linkage my friend made for it and it works fine .. for gas milage use the monojet carbs , they are much better than the old Rochester ...
Yes...the center opens 1st. But like said, On a 2 carb setup you don't need progressive linkage. :chevy:
just trying to get my facts straight before i go dump my cash into something that won't work.. ;) |
sorry for all the questions... but is the three carb setup worth the extra cost? ($299 vs 279 for manifold and an extra $179 for another carb..)
http://www.summitracing.com/parts/big-11510flt/reviews
http://www.summitracing.com/parts/he...make/chevrolet anybody see a difference in these headers, other than brand and price? |
Cifford manifold : $299 Offenhauser manifold $279 Clifford headers(short tube) $340 (Long tube) $420(?) Hedman headers $204 Tom Langdon's headers $277 Two new Model b rochesters. $327.94 from summit Edelbrock 500 cfm 1404 4 barrel $309.97 So....With a Clifford intake, Tom Langdon's headers and an edelbrock 500 yer looking at $885 and whatever shipping. Now if you were to do the same thing with two new rochesters, an offenhauser intake and Langdon's headers yer looking at $883...no difference, but the issue with the offenhauser is that the water lines are hard to hook up...the clifford intake utilizes heater hose for the water heated intake. So if you want good lasting quality...go with the clifford intake and either a set of Tom Langdon's headers or clifford's headers...the premium carb would be a 390 holley, but a mildly jetted down 500 edelbrock should work as well....and you'll want to convert to an hei as well. :chevy: |
