-   -   What carb base gasket should I use? (https://67-72chevytrucks.com/vboard/showthread.php?t=651842)
Gregski 12-03-2014 10:44 PM
4 Attachment(s)
I did not realize I would have to give a second thought to which base gasket to use with a Holley 4160 carburetor and the Weiand 8120 intake manifold, but now I see there are at least three choices.
This is what the intake looks like and the three base gaskets.
A. 108-10 one square hole
B. 108-18 two oval holes
C. 108-58 four round holes
Which one would you recommend and why? Please be kind I am honestly trying to learn something here as I honestly do not know the benefits or limits of each?
Caleb 12-04-2014 12:48 PM
Re: What carb base gasket should I use?
i use the square bore intake gasket. the first one. why? i dont know id have someone smarter than me shed some light on that one.
bnoon 12-04-2014 01:56 PM
Match the intake manifold. Single plain uses the open style, dual plane the split. Usually only the old school or stock replacement style manifolds use the 4 hole.
Gregski 12-05-2014 12:51 AM
Thank you Holley Tech Support gave me the same recommend, see below.
"Hello,
Thank you for contacting Holley Performance Products. Personally I would suggest an open plenum gasket - 108-10.
Sincerely,
Colin Kinser
Holley Technical Service"
GMC Guy 12-05-2014 12:58 AM
throw a 1" phenolic carb spacer on there while you're at it ;)
http://www.summitracing.com/nv/parts/sum-g1412
Gregski 12-05-2014 01:02 AM
you know me and a buddy of mine were at this place in town called Tognotti's Auto World and he said the same thing, I honestly don't know what the pros or cons of such implement are yet so I don't want to get a hernia trying to figure it out, that and start WWW III with a discussion here about those things, LOL
GMC Guy 12-05-2014 01:30 AM
well, not trying to spark any debates, but it solved a hot start issue with my truck after converting to an aluminum intake and edelbrock carb. the carb would get "heat soaked" after shutting it off for say 30 mins to an hour. I know you're going with a Holley (I spied on your build thread haha) but I'm sure the materials used to cast the carb body are similar.
Anyway, I tried the 1" phenolic spacer (4-hole) and *Poof* problem solved ;)
plus, it did add a little power off the line...
Koffer 12-05-2014 08:36 AM
I would call the tech support of the company that made the manifold , not the carb manufacturer .
If it was me ,I'd use gasket 2 as it's a dual plane manifold .
andrewmp6 12-05-2014 08:46 AM
Gmc guy is on point a carb spacer can save you from having heat soak in the summer.
Gregski 12-05-2014 11:39 AM
Originally Posted by Koffer (Post 6945299)
I would call the tech support of the company that made the manifold , not the carb manufacturer.
Same company, lol
I'm with you, so I emailed Holley/Weiand Tech Support back and they replied:
"That gasket will work fine also."
Kinda wishy washy if you ask me, I am the type of guy who wants to know why or why not or what the benefits are of each, know what I mean. I likes to learn.
rich weyand 12-05-2014 11:51 AM
If keeping the planes separated did not matter, there would be no reason to run the separator on the manifold all the way up to the carb base. Use the split gasket (#2) or the four-holer (#3).
Caleb 12-05-2014 12:00 PM
Or you can buy a heat shield for your carb. I had to trim a little off the front due to the thermostat housing but here on the coast when it gets hot it helps a lot.
McSwine 12-05-2014 03:46 PM
I was thinking the same thing. Did wonders for mine.
Koffer 12-05-2014 06:47 PM
Originally Posted by Gregski (Post 6945442)
Same company, lol
Here's a link to some learn'n :sexy:
http://www.enginelabs.com/engine-tec...or-dual-plane/
Gregski 12-12-2014 12:04 AM
Great article!
Gregski 12-12-2014 12:06 AM
so my Holley carb arrived today and guess what gasket it came with? Thought I would just throw that out there
Caleb 12-12-2014 10:46 AM
Now all you have to worry about is tuning it. thats the best part....
Gregski 01-01-2015 12:31 PM
I concur, so I ordered the 108-18
