tranny humps
In the square bodies are the tranny humps bolt in for the manual tranny equipped trucks like the 72 and earlier trucks?
Re: tranny humps
certain years are
Re: tranny humps
I saw a members build, 1974 I believe, and it had a removable hump. I'm looking to put a SM465 in my 86 K5 and will need the hump removed. I'd rather not drill out the spot welds if I could just cut a hole and then bolt in a tranny cover.
Re: tranny humps
They were bolt in until about 83' / 84'.
Re: tranny humps
Thanks!
Re: tranny humps
I think there is one in the for sale section. :lol:
Re: tranny humps
My 89 square body had a bolt in too. The answer isn't cut and dry.
Re: tranny humps
I have an '86 4x4 4 speed. the cab was shot. I got another cab witch is still '86 but 2wd. I cut my hump out if my 4x4 ,laid it in the 2wd traced it out and made the new hole 2" smaller and used an insert gun to put threaded inserts in the floor to bolt the hump back in. looks and works good.
Re: tranny humps
Re: tranny humps
I've always seen bolt in ones-I have an extra one in nice shape if you need one. The tool used to install the riv-nuts is called a riv-gun and you can buy different sizes of riv-nuts. After drilling the holes as Jeff said, installing them is a breeze.
