Want advice on bagging & Z-ing frame on a 63
2 Attachment(s)
Hi, new guy here looking for advice on a project.
I just picked up this 63 short bed fleetside big back window and I'm ready to start on it. I've seen so many excellent builds here so I knew I had to join. My main inspiration was jdoisher's build Maggie's Custom http://67-72chevytrucks.com/vboard/s...d.php?t=531177 Here's a couple pics of when I brought it home and where I'm at now. This has to be a budget build. I bought step notches which came in a couple days ago. I'd like to use the factory trailing arms. But, I'm undecided what to do on the front. First guess is to Z the frame and cup the LCA's. I was going to get drop spindles until I found out I have to convert to disks. Disks are fine, but again with the "budget build" thing. Any suggestions/opinions are welcomed. |
Re: Want advice on bagging & Z-ing frame on a 63
my favorite year and style! I'll be watching
Thanks, mine too
PB stage 1 front, nothing in the rear right now (rear end sitting on frame). Will be running their basic rear ($899).
I was going to do a Z, but realized it's pretty damn low as is. This pic is without the outer rockers, so add another 2-3" from the bottom of the door. https://scontent-a-dfw.xx.fbcdn.net/...12262223_o.jpg |
Looks KILLER w00dst0ck! any new updates?
this is a squarebody, but the principle is the same. kyle just happens to be working on this right now.
http://i103.photobucket.com/albums/m...jpeg_0-2-5.jpg motor is hanging, not attached to the crossmember, you can see the cherry picker behind. vertical lines are cut lines, horizontal lines are 2" |
