Truck Wont start!
alright, well pretty much as the title says, i have a no start. it starts if gas is put in the intake but dies out when its all used up. i know its a fuel problem, i just replaced the gas tank and it was running fine after that, and then one day i had it running fine and i turned it off and went back to start it again and it wouldent start. any tips?
Re: Truck Wont start!
Is the fuel pump kicking on? (assuming you have the electric one in the tank still)
Ground wire to the sender/fuel pump came off frame?
well I went out and tightened down the ground cable and still no start. I put some gas down the TBI and she just sputtered. but, the battery is weak now so its charging up now. any other things it could be?
Is this a single or dual tank setup?
Check the fuel pump relay/fuse. Is the fuel filter good? Is there any pressure on the fuel On key on have someone listen by the tank to make sure the pump kicks on (its a whining noise) This sounds crazy but bang on the bottom of the tank if you don't hear a noise.. The pumps will lock up and banging on the tank can get them unlocked and working temporarily. If it does start however you still need to change the pump. |
Never work on old stuff without replacing rubber vacuum hoses, fuel lines, coolant hoses, and flexible brake lines. If you did just re-use the old stuff, you might replace that first, before dropping the tank. That may or may not be the problem, but it should be done anyway, and it's easy and cheap. Oh, and new clamps too. |
