-   -   carb for '66 chevy 250 (https://67-72chevytrucks.com/vboard/showthread.php?t=652505)
fscboss 12-10-2014 01:51 PM
what is the best carb to replace the stock carb? i don't want to change the intake. the truck runs good just needs a little more fuel and air.
MitchFloyd 12-10-2014 03:14 PM
Re: carb for '66 chevy 250
http://www.langdonsstovebolt.com/sto...=0&sort=normal
Lokin4AReason 12-10-2014 04:33 PM
they have a adapter plate that you can use a 2bbl on a 1bbl intake
POISONIV 12-10-2014 08:28 PM
Still getting my stocker tweaked, I hope someone recommends for you the best proven factory intake set up carb.
I need something also...
bones1st 12-10-2014 10:06 PM
I picked one up at O reilly's auto parts to replace the stock one and it worked perfect. I think it was like $200.00:chevy:
TJ's Chevy 12-10-2014 10:21 PM
Trans adapt adapter and 350 holley 2 barrel. Plug and play..bolt on and go. :chevy:
Fla Grown 12-11-2014 01:24 PM
I just installed Tom Langdon's Weber 32/36 on my rebuilt 250 I purchased from him as well and it runs great. Smooth accelleration, great idle, starts up with one turn of the key. I would also suggest an upgrade to his HEI Distributor.
dracko 12-13-2014 01:02 PM
Another vote for Langdon's weber 32/36. Put one on my 230 and it runs like a champ. Smooth acceleration and actually decent punch when the secondaries open up. Decent mileage if ya roll around town with the primaries all day.
The one and okay drawback is that I couldn't figure out how to set the choke up properly for cold winter mornings...but that is likely more the operator than the carb.
