-   -   Rusty's Baseline Dyno Test (https://67-72chevytrucks.com/vboard/showthread.php?t=653149)
Gregski 12-16-2014 10:12 PM
5 Attachment(s)
Decided to have my '74 GMC 1500 dyno tested before bolting on any shiny performance bits. Rusty is almost all stock except for a few things.
Specs:
350 V8
4 Speed Manual
4 Barrel Rochester Quadrajet
No AC
Modifications:
LMC Truck 2 1/4 dual exhaust with Turbo Mufflers
A.I.R. Air Injection Reactor System - Delete
Here are the results of the three pulls:
1. 172 HP @ 4100 and 259 Tq @ 2600
2. 183 HP @ 4300 and 264 Tq @ 2900
3. 188 HP @ 4100 and 267 Tq @ 3000
* I am eye balling the RPMs for you
This was my first Dyno Test for any vehicle and cost $80 at a place called Evil Genius Racing in West Sacramento, California. John is a super cool guy, if you are local you may want to check them out.
cadillac_al 12-17-2014 08:31 PM
Re: Rusty's Baseline Dyno Test
Nice baseline. Aren't these trucks rated at 185 hp anyway? How many miles on yours? Does it rev or pull past 4100 rpm or is that just where max power was? What gear to they test in? I assume 4th or 1:1 gear.
y5mgisi 12-17-2014 09:17 PM
Good base!
gramps77 12-18-2014 01:43 PM
3 pulls for $80 correct?
Gregski 12-19-2014 12:54 AM
160 @ 3800 RPM according to the 1974 Light Duty Truck Service Manual, I attribute the additional horse power to the less restrictive dual exhaust and the deletion of the SMOG systems
Odometer reads 34,457 so I am guessing 234,457 as it's hard to put on a ton of miles on a farm truck, probably not much highway driving
Yes it revs passed it, we let off at 4,500 RPM
Good question, I don't know I will have to ask.
Gregski 12-19-2014 12:55 AM
Yes
Gregski 12-22-2014 04:39 PM
just wanted to share a little trick John did for one of the pulls cause he thought the air cleaner snorkel is too restrictive
I am all about little tricks like that, maybe some of you have seen this done already, but I haven't, yet it is so simple (and yes my air filter is dirty as heck, going to replace it and the air cleaner housing next month)
monte0185 12-23-2014 10:25 AM
188hp at the wheels is not bad at all. Remember the old hp and torque specs were done at the flywheel not the wheels.
Dball 12-23-2014 11:20 AM
This is what I was thinking, sounds like a healthy base line for sure.
slotard 12-23-2014 11:28 AM
I'm impressed that it's putting down that much power stock. I ought to dyno mine eventually but with 350/350, 4.10s, and currently 30.5" tires it's no fun on the freeway.
Corts60 12-23-2014 12:16 PM
That's awesome. I need to go have my non-turbo diesel tested so I can have a good laugh.
motornut 12-23-2014 12:42 PM
some swear they were made to do that "flip".
but no all fit
sounds louder too,I want to make one stocker a dual snorkel
77 350 Shorty Wide 12-23-2014 02:07 PM
The air filter flip has been around along time. I remember my dad doing it on his '69 El Camino. I did it on my new '77 1/2 ton stepside when I got back then.
If you have a truck with stock exhaust the intake sound when you open it up is far more impressive, especially in the cab.
Happy Holidays and God bless, Terry
justcuz 01-02-2015 03:44 PM
What I have done is take the snorkel off the air cleaner. It is spot welded on. Them I take a piece of cardboard and trace the oval pattern and transfer one to the other side of the air cleaner and one in the back. Then the air cleaner has three large oval holes in it and retains the breather for the crankcase to the rocker cover. On models that have the breather inside the air cleaner base I just cut the entire bottom off of the air cleaner.
86c20 01-02-2015 09:48 PM
nice nubers to start with. but i hope that you dont really think your truck is rusty??? i could show you pix of my c20 and my ramp truck that are on the road and pass inspection that make southners cry lol
Gregski 01-02-2015 10:34 PM
Sounds interesting, do you have any pics?
cadillac_al 01-03-2015 09:15 AM
This power curve is just perfect for the average driving that I do (now). 90% of my driving is between 2000-3000 rpm and the trans shifts at 4500 at WOT. I have to replace my cam this summer and I hope the aftermarket can supply me with a cam with max efficiency at 2500 rpm.
justcuz 01-03-2015 02:04 PM
Yes I think I can come up with a couple later today.
MikeB 01-03-2015 09:37 PM
1500-3000 RPM with a max of 4500 (if that much) is where a good driver needs to make power. There are lots of aftermarket cams that will work well for you. The inexpensive Summit Racing SUM-K1101 cam would do the trick, and possibly their K1102 depending on your truck's axle ratio and compression. Some of the newer design cams, like the smallest Lunati Voodoo or Crane Z-series, should work even better.
