1984 stepside 4x4
*copied from another forum*
picked this up last week, traded my 96 4runner for it. 1984 short box stepside, 4" lift (with blocks for now till I order a shackle flip), 35" tires, crappy rattle can camo paint job (will fix this), theres 4,000 miles on the TH400/NP205 and 383 stroker, 1800 stall converter, 3/4 ton axles with 4.10 gears(SF rear). Plans the paint is flaking and thin in spots so im thinking if I run it into the steam bay at work I can get most of it off. then I will decide from there on how good it comes out. build new bumpers front and rear and mount my winch and LED light bar. shackle flip when I get my tax returns im going to drop in a 5.3L and sell the stroker. here she is in all her glory http://i944.photobucket.com/albums/a...pse94116c8.jpg http://i944.photobucket.com/albums/a...pse6410bdc.jpg http://i944.photobucket.com/albums/a...ps11c46108.jpg the paint has to go, so I took it into the steam bay at work and it was working, but it was working too well lol, took it down to bare metal in a couple spots so I stopped, I will just sand it down a bit and paint it all one color. http://i944.photobucket.com/albums/a...pscd4bdf09.jpg over last weekend I brought it into the shop. it had quite a few leaks going on, the P.O bought new polished aluminum valve covers for it but never put them on, so I put those on. pulled the oil pan off, cleaned, painted, and reinstalled with a one piece oil pan gasket. rear diff was leaking so I pulled the cover, lots of shavings on the magnet in there and pitting on the spider gears, here's hoping she holds out till I can get a set of tons put in. http://i944.photobucket.com/albums/a...ps52ec9764.jpg one of the PO's frenched the original lights into the fenders. http://i944.photobucket.com/albums/a...psc9149956.jpg |
Re: 1984 stepside 4x4
*all caught up now*
replaced the heater hoses, thermostat, thermostat housing, and installed a recirculating engine heater. |
is that a....power brake booster filter used as a fuel filter?
no its a napa fuel filter, I have a new see through glass one for it. just need to install it and get rid of the "braided" hose
Love stepsides. Nice. Sweet 8 lug running gear.
finally got the recirculating block heater installed that my wife bought me last christmas.
http://i944.photobucket.com/albums/a...ps9a9aa6fd.jpg and the plug http://i944.photobucket.com/albums/a...ps15cec41e.jpg http://i944.photobucket.com/albums/a...psf504ae6e.jpg http://i944.photobucket.com/albums/a...psf01c46d8.jpg |
cleaned out the bed, took a spare sheet of plywood and screwed it down for now to cover the rotten boards, then mounted a truck box i had in the blazer. till it started snowing too much.
http://i944.photobucket.com/albums/a...pscf95e90e.jpg |
Following...............
I like the "No ****s given" attitude with the block heater oulet, Haha. I'll be following the build.
got the title and plates taken care of so now I can move forward on mods for it...... after Christmas lol |
Saturday I took my kid out sledding for his first time, he had a blast, went by himself on the first time lol.
http://i944.photobucket.com/albums/a...ps7868e879.jpg he got a better idea of how it worked on his next one http://i944.photobucket.com/albums/a...ps99c34bd7.jpg and since this is my thread about my truck http://i944.photobucket.com/albums/a...psb6261032.jpg |
nothing picture worthy but I rebuilt the front driveline yesterday, took way longer than it should have, ended up rebuilding the cv along with changing u-joints. my son was there the whole time asking all kinds of questions, so proud to have a 3yo who is interested in trucks.
about a month ago the truck came up with a problem where I had to keep it half choked off just to be able to drive it. hooked up a transducer in the fuel line and took it for a drive to check fuel pressure under a load. at an idle this engine needs 4psi and at full throttle it needs about 9psi, I had 4 psi at an idle and clear down to 3.1psi at full throttle. it took me a month to finally get a day and weather to work on this, but.....
today I said good bye to the piece of junk fuel starver http://i944.photobucket.com/albums/a...ps7mogow8u.jpg and said hello to old reliable http://i944.photobucket.com/albums/a...pskii7coza.jpg I still had a little stumble when bumping the throttle so I went to adjust my carb set screws, and one had backed out like 3 turns (I had just adjusted it a month ago). little lock tite and we should be good there. all in all it runs and starts a lot easier now, don't have to crank it for a minute to get it to fire up. also since I was at it, I installed my new tailgate hinges, I only had one in there and a bolt shoved in backwards on the other side. theres not that much gap normally, I had the gate shoved to one side. http://i944.photobucket.com/albums/a...psrdhafk0m.jpg |
