-   -   Nice 400 Kickdown switch on ebay (https://67-72chevytrucks.com/vboard/showthread.php?t=653722)
70cst 12-22-2014 02:02 PM
There are still good buys on ebay.
Got this 400 kickdown switch with the harness for $51.
Normally the kickdown switch does not come with the harness.
Life is good.
john 12-22-2014 04:39 PM
Re: Nice 400 Kickdown switch on ebay
Have a link?
70cst 12-22-2014 06:09 PM
http://www.ebay.com/itm/161499657417...%3AMEBIDX%3AIT
70cst 12-22-2014 06:14 PM
I was a .98 off
davepl 12-22-2014 07:14 PM
Are they hard to get? I think I have a couple and have to imagine they came on about 20 million vehicles between 1964 and whenever the 4L80E came along in about 1987. That's 23 years of production, and it was the only HD auto GM used with any regularity (except he powerglide).
leddzepp 12-22-2014 07:18 PM
They are somewhat scarce, believe it or not. When you do find one, the wire harness is usually spliced, cooked, or not present at all as Dewayne noted.
kwmech 12-22-2014 07:27 PM
They all seem to be missing the piece that bolts to the carb linkage that pushes on the button at full throttle. Kinda useless without it
mechanicalman 12-23-2014 12:56 AM
I guess I'm lucky to have a 72, when I converted to a T400 I ordered a new GM switch, mounted it to the factory bracket above the accelerator pedal, and ran a couple wires; did not need a fancy harness.
mechanicalman 12-23-2014 12:59 AM
Like this one.
kwmech 12-23-2014 01:31 AM
Originally Posted by mechanicalman (Post 6968286)
Like this one.
That one is for the cable linkage and mounts inside on the pedal bracket. The one the OP showed bolts to the back of the carb. Like you said your 1972. I have a 69 that is missing the actual carb piece. I guess what may be the only resolve is to convert to cable at a future date
FirstOwner69 12-23-2014 01:48 AM
Like this...
kwmech 12-23-2014 01:52 AM
Originally Posted by FirstOwner69 (Post 6968333)
Like this...
Yup! Exactly. Know where I can get one? The previous owner of my 69 swapped out the q-jet, that piece didn't make it'
Thanks for the pic
leddzepp 12-23-2014 01:55 AM
Looks like it would be pretty easy to fabricate something that would work.
kwmech 12-23-2014 02:00 AM
I could, but I just don't have the time. I need to complain about it more first. But it is not too often that I really need passing gear. I was just making a point about all the sellers that don't give you all the pieces or just don't know what they are selling or how it works
leddzepp 12-23-2014 04:21 AM
Yeah, I hear ya. Most people that buy these particular switches already have one in place and buy one as a back up since they are hard to find. They are easy to bench test and I notice most sellers offer them up "as-is" or "untested" when they do come up for sale.
special-K 12-23-2014 08:00 AM
I have a tH400/NP205 set-up slated to go in my '72 once I build the 383. If I found a complete '72 kickdown assembly w/harness I'd hop right on it. This one with harness is tempting. it;s what this lacks that the ones I see lack, though, as KW mentioned. The biggest reason i'm not going for this is it's sold! Dag nabbit!
