-   -   fan shrouds (https://67-72chevytrucks.com/vboard/showthread.php?t=654041)
gmcdeadhead 12-26-2014 04:01 AM
fan shrouds
what other year truck fan shrouds, or car , would fit our 1966 v8 truck with little or no modifications?
pimpston65 12-26-2014 05:35 AM
Re: fan shrouds
im sure as long as its wide enoughto attach to the side wings any one will fit, i have one from 67-72 era im not using, you can have it!!!
gmcdeadhead 12-26-2014 05:22 PM
Re: fan shrouds
pm sent pimpston65
southern parts 12-26-2014 06:39 PM
Re: fan shrouds
I have a 64 impala fan shroud on my 64 burb. had to trim a little off the flanges on each side.
duallyjams 12-26-2014 07:21 PM
Re: fan shrouds
got a pic to share
southern parts 12-27-2014 11:56 AM
Re: fan shrouds
I forgot , I also trimmed some off of the tunnel part too
DPowers 12-27-2014 10:35 PM
Re: fan shrouds
I have two V8 ones if you are interested. Both would need minor repair.
algiese 12-28-2014 01:30 AM
Re: fan shrouds
Also looking for a V8 shroud....
90810 Long Beach Ca
Kenfuzed 12-28-2014 01:59 AM
Re: fan shrouds
I had been looking for one but finally grew impatient and bought an aluminum shroud kit from Summit. I had to trim the hoop back since my engine sits forward and the fan needed to be half in half out for proper flow. But if the engine sits in the rear (stock) position the ring doesn't need modifying.
Here are the fan shrouds. You'll want to select one that is closest in dimensions to reach around whatever radiator you are using.
http://www.summitracing.com/search/p...=Fan%20Shrouds
http://67-72chevytrucks.com/vboard/a...1&d=1416798265
Grizz1963 12-28-2014 04:46 AM
Re: fan shrouds
One of the things I need to figure out on my rebuild.
My shroud is zip tie special with much thick black brush paint.
Need to find a decent donor in the UK.
61_FL_Apache 12-28-2014 03:36 PM
Re: fan shrouds
Ken, your summit shroud kit looks great!
LostMy65 12-28-2014 05:49 PM
Re: fan shrouds
I agree!
Kenfuzed 12-29-2014 02:03 AM
Re: fan shrouds
Thanks, I actually consider myself fabricated-challenged so if I could do this almost anyone can. It would be easier for anyone not needing to trim the width of the ring. The stock width would have placed the fan too deep for me. The band is a long strip that is approx 3" wide so I took a jig saw and ripped down the length to remove around 1.25" of the width. I recommend this shroud kit for anyone wanting an efficient solution and not requiring an original shroud.
gmcdeadhead 12-29-2014 03:41 AM
Re: fan shrouds
how well does the shroud from summit racing move air?
Blainethemono 12-30-2014 02:07 AM
Re: fan shrouds
Ken, that's your std Chebie small block I assume, & do you remember the part number from summit? The 19" one perhaps.
Thanx!
Kenfuzed 12-30-2014 02:38 AM
Re: fan shrouds
I can feel air being pulled from the front even in the corners. At high idle it will hold a dollar bill against the front of the radiator, but then again my truck can find a way to suck money just about anywhere.
Thanx!
Found my order info, here is the link.
http://www.summitracing.com/parts/SUM-380482-SH
The shroud's box portion is 19x26 which fit pretty good around my Champion aluminum radiator.
pimpston65 12-30-2014 11:21 AM
Re: fan shrouds
here are pics of the 67-72 style i have...
pimpston65 12-30-2014 11:22 AM
Re: fan shrouds
another pic
