Tracking arm needed?
Hey guys,
So I am in the middle of installing my last c notch and realized that the "tracking arm" (I think that is what its called?) that is connected to the axle to the frame is in the way. So I guess my question is do I really need it? What did you guys end up doing with it? Should I install the notch in and drill a new hole for the tracking arm holder? What is the purpose of that anyways? Thanks! |
Re: Tracking arm needed?
http://www.earlyclassic.com/catalog....per track bars
Early Classic Enterprises Super Track Bar |
the trac bar centers the rear end. the more you lower the frame the more off center the rear end will be. a longer trac bar will be needed if you lowered the truck so you had to install c notches. i used the one from early classic but the porterbuilt i think comes with a new mount that goes to the frame
http://www.classicperform.com/Chevy-Truck.htm
Check out CPP also, scroll down on the page. Awesome parts and customer service. |
