-   -   Gas Gauge (https://67-72chevytrucks.com/vboard/showthread.php?t=655849)
ChuckyC 01-10-2015 12:57 PM
Gas Gauge
I have a 62 c-10 with the original fuel tank and sender, but after market gauge. The gauge is an equus gm 0- 90 ohm, when the tank is full the gauge only goes as far as one quarter. I was told I could put a resister in the line to correct this problem, but do not what resister to use. Can someone help me?
ray_mcavoy 01-10-2015 03:06 PM
Re: Gas Gauge
Your original sending unit is 0Ω (empty) to 30Ω (full). Unfortunately, there is no way you can simply add a fixed value resistor to the circuit and have the 0 - 90Ω gauge give you correct readings at all fuel levels.
I don't think there are any 0 - 90Ω sending units out there that will fit the stock fuel tanks in these trucks. There might be a universal sending unit that could be adapted. But the easiest fix will probably be to buy another gauge that is designed to work with the 0 - 30Ω sending unit.
65sub 01-10-2015 03:07 PM
Re: Gas Gauge
changing the fuel sender might be a better solution. Adding a resister would only shift the reading up the scale
vin63 01-10-2015 04:06 PM
Re: Gas Gauge
Just in case...http://67-72chevytrucks.com/vboard/s...d.php?t=288717
64chevmn inquired about one earlier this week. If you both order one, I would give you both the multiple order discount.
