power steering pump bracket
I have a 75 chevy 350 in my 66 and am wanting to put power steering on it. I have the short water pump and the brackets I have for the pump is for the long water pump. I am putting the alternator up top on the drivers side like it was in 66 hooked to the exhaust manifold. What bracket do I need for the low mount pump? Pictures would help. Thanks.
Re: power steering pump bracket
there use to be more in the FAQ on this but it was gutted. they had this part under motor mounts and it is the rear support bracket for the pump.http://67-72chevytrucks.com/vboard/s...d.php?t=609833
here is another which will show you the setup http://67-72chevytrucks.com/vboard/s...d.php?t=633432 ron |
I have a pump off of a 1975 Chevy truck will this bracket work with this pump?
