-   -   '83 steering colmn in a '72 C10? (https://67-72chevytrucks.com/vboard/showthread.php?t=670471)
Tivio4 05-13-2015 04:01 PM
How easy? To put a Tilt steering column shift out of a 1983 Blazer into a '72 column shift C10? Not worried about relocate ignition or other options.
hugger6933 05-13-2015 05:45 PM
Re: '83 steering colmn in a '72 C10?
The main problem with that is the size it does matter. Our type trucks have a smaller diameter column than the newer trucks and you will probably end up cutting the dash bezel at the least to get the thing to fit in your truck. Find a van column or better yet the P30 motor home chassis trucks carry almost identical columns to our trucks up 85 I know for sure as I have a 85 with one in it.
Tivio4 05-13-2015 05:53 PM
Thank You for the input. As I need to do something and 1983 Blazer Tilt column with steering wheel on local craigslist asking $75.
