-   Squarebody Projects and Builds (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=139)
-   -   Isuzu NPR LQ4 Questions (https://67-72chevytrucks.com/vboard/showthread.php?t=671810)
Rich84 05-26-2015 10:05 AM
I removed an LQ4 from a wrecked Isuzu box truck this weekend. The oil pan measures about 5" deep in front. I'm thinking that this will fit very nicely in my '84. Could it be an Fbody type of pan because of the way it fits in the truck?
Also, there appears to be a vacuum pump of some sort on it. Can I use that for my brake booster, or should I just find somewhere else on the intake manifold?
Rich84 05-27-2015 03:31 PM
Re: Isuzu NPR LQ4 Questions
Maybe I should have posted this in the LSX section..
bnoon 05-28-2015 08:34 AM
I found this via Google. Should help you identify the oil pan for certain. http://ls1tech.com/forums/conversion...-oil-pans.html
As for the air pump, need more information/pictures. For the brake booster though, it's fed off of the vacuum nipple located on the rear driver's side of the truck style intake.
Rich84 05-28-2015 09:04 AM
It does look like the f-Body pan to me..
This is the vacuum.
Attachment 1408604
downeyballz 11-02-2016 06:54 AM
do you have any more pics of the engine? Im curious about the differences between your box truck engine and a normal lq4.
Rich84 11-07-2016 05:07 PM
3 Attachment(s)
Attachment 1587908
Attachment 1587909
Attachment 1587910
