-   -   My fully restored manifolds :) (https://67-72chevytrucks.com/vboard/showthread.php?t=672679)
weider1717 06-02-2015 09:06 PM
2 Attachment(s)
This is what happens with a NCRS members owns an 87 pickup :lol: Turned out great just cost me a spot welder to get the correct heat shield welded correctly as original. That was a bummer but I didn't trust any shop around to spot weld it without burning right through that pot metal shields.
Attachment 1410995
Attachment 1410994
65standard 06-02-2015 09:47 PM
Re: My fully restored manifolds :)
Look beautiful, will the finish last longer than the original bare cast iron and rust instantly?
weider1717 06-02-2015 09:54 PM
I used por-15 I have used this product before on a vehicle back in 2005 or so and the manifolds still look the same as I put them on.
There are even better ways but this should be fine for my needs.
87ChevyR10 06-02-2015 10:03 PM
Looks good!!
77K10Silverado 06-03-2015 10:46 AM
So the POR15 doesn't burn off?
weider1717 06-04-2015 06:59 AM
No, the POR-15 from my experience will last a very long time under weekend driver conditions. I say that because I have a weekend car I restored in 2005 and they still look new!
I always do 3 coats letting it fully dry in between for 24hrs. Be aware if you do this right and take the shields off to get to the entire manifold to coat it those rivets are a PITA to remove! Mine both broke up they were seized.
1970pelle 06-04-2015 10:06 AM
Very nice work, something to be proud of. Ken
weider1717 06-07-2015 10:29 AM
thanks guys, should help the engine bay look a lot cleaner.
weider1717 06-30-2015 12:15 PM
just wanted to add it's usually a good idea to have the surfaced machined due to warpage since you don't put gaskets on these or at least that's the way they came. :metal:
Tom 06-30-2015 06:04 PM
Those manifolds looks perfect! Can I ask why you put this amount of effort and money into stock manifolds? I get everyone has their reasons, just curious.
