-   LSx Swaps (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=206)
-   -   Front accessory drive opinions (https://67-72chevytrucks.com/vboard/showthread.php?t=672969)
ztk123 06-05-2015 05:14 PM
I'm trying to decide if I should use the OEM brackets that came with the ls6 I bought or Kwik performance brackets. I have both setups minus a high mount a/c. I like the looks of the Kwik performance system. I'll probably have to run a high mount a/c and will have to purchase an a/c bracket. I have read about some alignment issues people have had with the Kwik performance stuff. Any advice, experience or input welcomed.
Thanks,
Mike
solidaxel 06-05-2015 06:34 PM
Re: Front accessory drive opinions
Thanks I was just about to look at options for a new factory 6.2 that does not come with any front items, except a "water pump"
so everything will be needed including A/C pump P/S and Alt
bpatrol 06-07-2015 03:09 PM
run the stock f body brackets and use the kwik performance ac bracket. I do prefer the dirty dingo bracket for ac myself but both are quality units
bpatrol
ztk123 06-07-2015 10:30 PM
Thanks for the input bpatrol!
